Topic: Connection lines angled - not straight
Dear All
I have questions myself quite often why the connections lines of elements when close together always get additional angles and not straight connections. Please see my pictures attached.
If I connect the "T" with the PA-Element the connection line is not straight, but it jumps around in a undefined loop.
I wonder why it is not possible to make straight lines without any angles, etc.
I`m using 0.100.
Thanks
Chris
Re: Connection lines angled - not straight
I can't say for sure. I've never had that problem.
However, it looks like your connection isn't properly aligned. Could that be causing the problem?
No. This always happens. As soon as the components are closer together these angles and hooks are created. All is good if they are "far" away.
could a share an example project?
I can.
As an example the parts on the top, and also left bottom side, shows additional lines, not needed.
Another example.
The top connection is fine, straight and sound connection.
The bottom, though it is not so close, the line do not connect in a proper 90° way, but makes
this additional hook.
It`s necessary to pull down the line to get a proper connection.
Why?
c.lehner wrote:
I can.
c.lehner wrote:
I can.
Where should be the extra lines? i dont see them.
Which Version do u use?
