Topic: Connection lines angled - not straight
Dear All
I have questions myself quite often why the connections lines of elements when close together always get additional angles and not straight connections. Please see my pictures attached.
If I connect the "T" with the PA-Element the connection line is not straight, but it jumps around in a undefined loop.
I wonder why it is not possible to make straight lines without any angles, etc.
I`m using 0.100.
Thanks
Chris
Attachment icon Conn.jpg 31.36 kb, file has never been downloaded.
Attachment icon Notconn.jpg 25.94 kb, file has never been downloaded.
Re: Connection lines angled - not straight
I can't say for sure. I've never had that problem.
However, it looks like your connection isn't properly aligned. Could that be causing the problem?
No. This always happens. As soon as the components are closer together these angles and hooks are created. All is good if they are "far" away.
could a share an example project?
