1 (edited by mabee_steve 2026-02-12 16:20:52)
Topic: Simple terminal block symbol question
I have searched and read a bit about the terminal block plugin and watched a few videos, but I'm not understanding how it works. I also don't think it's what I want/need at this point in my projects. I'm drawing a simple motor starter schematic and I plan to use feed-through terminal blocks from
Weidmuller. I've been trying to understand how I can depict these devices in my schematic and wondering if the below drawing is the intended, correct way to do this.
https://i.imgur.com/f7r92nV.png
There aren't wire label text objects for each connection which also makes me thing I'm using these wrong or that there is a better way. For example if I had a 4 position terminal block and wanted to label the conductors 1.a, 1.b, 1.c and 1.d I would need to add text objects to the terminal parts and that seems like a warning that I'm using the wrong thing.
I've also seen the terminal strip diagram parts, but these are large (1) compared to the other symbols I'm using (2)
**I made a screen shot to show this but for some reason this site won't let me include more than 1 image which is pretty lame.
Warning! The following errors must be corrected before your message can be posted:
Too more links in message. Allowed 1 links. Reduce number of links and post it again.
Re: Simple terminal block symbol question
**J'ai fait une capture d'écran pour montrer cela, mais pour une raison quelconque, ce site ne me permet pas d'inclure plus d'une image, ce qui est plutôt nul.
C'est étonnant ! Il te faut peu-être re éditer ton post pour ajouter plus de fichiers images?
https://qelectrotech.org/forum/viewtopic.php?id=2343
En fait, j'ai essayé la même chose, mais cela n'autorisait pas non plus de liens supplémentaires lors de l'édition.
5 (edited by mabee_steve 2026-02-12 23:25:55)
J'allais répondre en français (en utilisant un traducteur) mais j'ai réalisé qu'il s'agissait du forum EN, il est donc probablement préférable pour moi de répondre en anglais.
^^Me explaining why I'm switching to English.
Should I take from your reply that I should be using the terminal block generator and not mess around with the parts displayed in my original post? I find the terminal block generator a bit intimidating and I don't understand how I can complete some concepts, for example:
  • How do I indicate that two terminals are bonded? (see below image for example of what I mean)
  • How do I handle multi-level terminals (2x 2-position terminals in one block)
https://i.imgur.com/64Xw9XU.png
