Topic: Simple terminal block symbol question
I have searched and read a bit about the terminal block plugin and watched a few videos, but I'm not understanding how it works. I also don't think it's what I want/need at this point in my projects. I'm drawing a simple motor starter schematic and I plan to use feed-through terminal blocks from
Weidmuller. I've been trying to understand how I can depict these devices in my schematic and wondering if the below drawing is the intended, correct way to do this.
There aren't wire label text objects for each connection which also makes me thing I'm using these wrong or that there is a better way. For example if I had a 4 position terminal block and wanted to label the conductors 1.a, 1.b, 1.c and 1.d I would need to add text objects to the terminal parts and that seems like a warning that I'm using the wrong thing.
I've also seen the terminal strip diagram parts, but these are large (1) compared to the other symbols I'm using (2)
**I made a screen shot to show this but for some reason this site won't let me include more than 1 image which is pretty lame.
Warning! The following errors must be corrected before your message can be posted:
Too more links in message. Allowed 1 links. Reduce number of links and post it again.
