Re: Qt 6.0 development and qelectrotech
Re-searcher wrote:
@scorpio810
Merci pour l'information.
Thanks for the information.
https://github.com/qelectrotech/qelectr … angeLog.MD
github_changelog_generator -u qelectrotech --token xxxxxxxxxxxxxxxxxxxxxxxxxxxx -p qelectrotech-source-mirror --base "" --since-tag= 543447aa31f42525967ed26223d2d388ecb6c55b --output ChangeLog.MD
git shortlog $(git describe --tags --abbrev=0)..HEAD > file3.txt
git log $(git describe --tags --abbrev=0)..HEAD --pretty=format:"%ar : %s , %an" > file4.txt
git log --graph --pretty=format:'%Cred%h%Creset -%C(yellow)%d%Creset %s %Cgreen(%cr) %C(bold blue)<%an>%Creset' --abbrev-commit > file8.txt
vi command :968,$d to delete lines after line 968!
127 (edited by Re-searcher 2025-09-28 13:00:13)
Y a-t-il actuellement des personnes qui travaillent à la programmation de Qt5 vers Qt6 ?
Are there people currently working on programming Qt5 to Qt6?
Zijn er personen die nu bezig zijn met het programmeren van Qt5 naar Qt6 ?
Où puis-je trouver les nouveaux fichiers pour Qt6 ?
Where can I find the new files for Qt6?
Waar kan ik de nieuwe bestanden vinden voor Qt6 ?
git clone --recursive https://github.com/qelectrotech/qelectrotech-source-mirror.git
cd qelectrotech-source-mirror/
git switch qt6-cmake
comment line 137 of /sources/machine_info.cpp to compile.
mkdir build && cd build
cmake .. -G Ninja -DBUILD_WITH_QT6=ON
time ninja -j48
Ignored 95 untranslated source text(s)
[318/478] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/UndoCommand/openelmtcommand.cpp.o
/media/backup6/qelectrotech-source-mirror/sources/editor/UndoCommand/openelmtcommand.cpp: In member function ‘virtual void OpenElmtCommand::redo()’:
/media/backup6/qelectrotech-source-mirror/sources/editor/UndoCommand/openelmtcommand.cpp:66:102: note: ‘#pragma message: @TODO uncommante slot_select when fixed, see itemChange function for each primitive’
   66 | #pragma message("@TODO uncommante slot_select when fixed, see itemChange function for each primitive")
[478/478] Linking CXX executable qelectrotech
real    0m36,019s
user    21m37,065s
sys     1m39,485s
QElectroTech V 0.100.0-dev
Compilation : GCC 15.2.0
Built with Qt 6.9.2 - x86_64 - Date : Sep 28 2025 : 12:58:45
Git Revision : 411fb3c4dc54b6aaea00f034d6c5396de5daa474
Run with Qt 6.9.2 using 48 thread(s)
https://download.qelectrotech.org/qet/forum_img_2/Qt6_test_build.png
See: https://qelectrotech.org/forum/viewtopi … 035#p22035
Debian 13 = Trixie
GCC = 14.2.0
Qt = 6.8.2+dfsg
Kernel : 6.12.48+deb13-amd64
avec cmake = erreur de compilation
avec qmake6 = compilation
with cmake = build error
with qmake6 = build
Compilation : GCC 14.2.0
Built with Qt 6.8.2 - x86_64 - Date : Sep 28 2025 : 16:08:57
Run with Qt 6.8.2 using 2 thread(s)
CPU : model name : Intel(R) Core(TM)2 Duo CPU P8600 @ 2.40GHz
RAM Total : 3 GB
RAM Available : 2 GB
GPU : Advanced Micro Devices, Inc. [AMD/ATI] RV635/M86 [Mobility Radeon HD 3650]
GPU RAM : Video memory: 256MB Dedicated video memory: 256 MB Currently available dedicated video memory: 255 MB
OS : linux - x86_64 - Version : Debian GNU/Linux 13 (trixie) - Kernel : 6.12.48+deb13-amd64
*** Qt screens ***
( 1 : 1680 x 1050 )
../sources/colorbutton.cpp: In member function ‘void ColorButton::clicked(bool)’:
../sources/colorbutton.cpp:56:32: warning: unused parameter ‘checked’ [-Wunused-parameter]
   56 | void ColorButton::clicked(bool checked)
../sources/colorcombobox.cpp: In member function ‘virtual void ColorComboBox::paintEvent(QPaintEvent*)’:
../sources/colorcombobox.cpp:80:45: warning: unused parameter ‘e’ [-Wunused-parameter]
   80 | void ColorComboBox::paintEvent(QPaintEvent *e) {
../sources/editor/UndoCommand/openelmtcommand.cpp: In member function ‘virtual void OpenElmtCommand::redo()’:
../sources/editor/UndoCommand/openelmtcommand.cpp:66:102: note: ‘#pragma message: @TODO uncommante slot_select when fixed, see itemChange function for each primitive’
Maybe with Debian Trixie, compile ok on Debian unstable.
GCC 15.2.0 with Qt 6.9.2 ...
@Erik: What time you need to compile QET on this old CPU : model name : Intel(R) Core(TM)2 Duo CPU P8600 @ 2.40GHz?
@Laurent
Toutes mes condoléances pour la perte de votre chien.
Je comprends très bien ce que vous vivez.
Mon frère et moi n'avons pas d'enfants. Mon frère a des poneys (petits chevaux). Deux d'entre eux sont morts à cause d'une attaque de loups. J'allais voir ces poneys (petits chevaux) tous les jours. Je n'arrive toujours pas à comprendre que ces loups soient protégés par l'Europe.
make -j2
real    37m45.343s
user    70m25.357s
sys    4m10.749s
git clone --recursive [url]https://github.com/qelectrotech/qelectrotech-source-mirror.git[/url]
git checkout qt6-cmake
time ninja -j48
merci beaucoup pour ces infos ! build OK avec CMAKE,  ma machine est sur cachy0S à jour (basé sur Archlinux).  Je verrais si je prend le temps pour tester avec QMAKE6.  et merci aux développeurs pour ce projet.
Compilation : GCC 15.2.1 20250813
Built with Qt 6.10.0 - x86_64 - Date : Oct 25 2025 : 16:47:49
Run with Qt 6.10.0 using 16 thread(s)
CPU : model name : AMD Ryzen 7 PRO 7840U w/ Radeon 780M Graphics
RAM Total : 23 GB
RAM Available : 16 GB
GPU : Advanced Micro Devices, Inc. [AMD/ATI] Phoenix1 (rev dd)
GPU RAM : Video memory: 8192MB Dedicated video memory: 8192 MB Currently available dedicated video memory: 6822 MB
OS : linux - x86_64 - Version : CachyOS - Kernel : 6.17.5-2-cachyos
*** Qt screens ***
( 1 : 1920 x 1200 )
( 2 : 3440 x 1440 )
( 3 : 2560 x 1440 )
@desaparecido: pour information, la branche qt6-cmake est tres loin d’être stable pour la production, je te conseillerai plutôt la branche master basée sur Qt 5.15!
https://github.com/qelectrotech/qelectr … /qt6-cmake
This branch is 61 commits ahead of, 136 commits behind master.
git checkout master
rm -Rf build
qmake ../qelectrotech.pro
time make -j48
136 (edited by Re-searcher 2025-10-30 20:09:36)
OS : GNU/Linux forky/sid
Il y a des erreurs dans le master (9e78dc5)
There are errors in the master (3cf9095)
/sources/qgpimanager.h
g++ -c -pipe -std=c++17 -O2 -std=gnu++1z -Wall -Wextra -D_REENTRANT -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_ALLOW_OVERRIDE_DD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DGIT_COMMIT_SHA=\"9e78dc56a87f3dda73e4980165ab60927495ebcd\" -DQET_LANG_PATH=/usr/local/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/local/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/local/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I../../qelectrotech-source-mirror-9e78dc5 -I. -I../SingleApplication -I../sources/ui -I/usr/include/KF6/KCoreAddons -I/usr/include/KF6/KWidgetsAddons -I../sources/TerminalStrip/ui -I/usr/include/x86_64-linux-gnu/qt6 -I/usr/include/x86_64-linux-gnu/qt6/QtSvg -I/usr/include/x86_64-linux-gnu/qt6/QtPrintSupport -I/usr/include/x86_64-linux-gnu/qt6/QtWidgets -I/usr/include/x86_64-linux-gnu/qt6/QtGui -I/usr/include/x86_64-linux-gnu/qt6/QtNetwork -I/usr/include/x86_64-linux-gnu/qt6/QtXml -I/usr/include/x86_64-linux-gnu/qt6/QtSql -I/usr/include/x86_64-linux-gnu/qt6/QtConcurrent -I/usr/include/x86_64-linux-gnu/qt6/QtCore -Irelease -I. -I/usr/lib/x86_64-linux-gnu/qt6/mkspecs/linux-g++ -o release/conductorautonumerotation.o ../sources/conductorautonumerotation.cpp
In file included from ../sources/diagram.h:28,
                 from ../sources/bordertitleblock.cpp:21:
../sources/qgimanager.h:52:14: error: ‘void QGIManager::manage(QVector<QGraphicsItem*>&)’ cannot be overloaded with ‘void QGIManager::manage(const QList<QGraphicsItem*>&)’
   52 |         void manage(const QVector<QGraphicsItem *> &items);
../sources/qgimanager.h:49:22: note: previous declaration ‘void QGIManager::manage(const QList<QGraphicsItem*>&)’
   49 |                 void manage(const QList<QGraphicsItem *> &);
../sources/qgimanager.h:53:14: error: ‘void QGIManager::release(QVector<QGraphicsItem*>&)’ cannot be overloaded with ‘void QGIManager::release(const QList<QGraphicsItem*>&)’
   53 |         void release(const QVector<QGraphicsItem *> &items);
../sources/qgimanager.h:51:22: note: previous declaration ‘void QGIManager::release(const QList<QGraphicsItem*>&)’
   51 |                 void release(const QList<QGraphicsItem *> &);
make[1]: *** [Makefile.Release:4515: release/bordertitleblock.o] Error 1
make[1]: *** Waiting for unfinished jobs....
                 from ../sources/conductorautonumerotation.cpp:23:
make[1]: *** [Makefile.Release:4563: release/conductorautonumerotation.o] Error 1
make[1]: Leaving directory '/home/me/me/QET/qelectrotech-source-mirror-9e78dc5/build'
make: *** [Makefile:42: release] Error 2
me@me:~/me/QET/qelectrotech-source-mirror-9e78dc5/build$
oh merci .. version master installé (qt5) .. je n'avais plus packages avec qt5 donc j'ai directement essayé la version qt6, je vais rester attentif à l'évolution, là je fait des test avec l'import des .DXF .. pff .. pas donné, merci pour votre travail
git checkout master
rm -Rf build
time make -j48
git checkout master
rm -Rf build
time make -j48
Salut Desaparecido,
si tu veux faire des tests je te conseilles de jeter un œil au travail giganteste de Oneil sur son fork github (IA?), je suis vraiment bluffé, et je le remercie grandement pour tous ce travail et ces analyses, certes certains forks que j'ai compilé rapidement comme aspect-ratio-folio cassent mes anciens projets..mais son travail et son analyse mérites d’êtres saluées., chapeau Oneil nomicons/wink
https://github.com/EmilOsvoll/qelectrot … hes/active
