Topic: Contactor name and reference messed up
Hi
I define a relay coil as K1, add a contactor and a switch and connect these with K1. Then, at the right side of the contactor and the switch, "K1" appears and the coordinates of the relay coil (1-B4 in my case).
But "K1" and "(1-B2)" are printed on top of each other, see attached image.
I found no other way to separate these two items than using an underscore and spaces for the name of the relay, e.g. "_ K1".
But there must be a way to separate these items. Does anyone konw how this can be done?
Thanks!
