1 (edited by leoshusar 2025-10-20 01:30:39)
Topic: How to draw bridged 3way or 4way terminal blocks
Hi!
Can you please help me with how can I draw and label three 4way terminal blocks (like Wago 2202-1401) bridged with a saddle jumper and all 12 of their wires connected? And also, does the terminal generator already support these?
I found something in EPLAN help, so I tried to do it the EPLAN way using multiple terminal blocks (https://www.eplan.help/en-us/Infoportal … path=EPLAN - Potential terminals), it almost looked fine, but I'm using auto numbering and I couldn't find a way to hide labels on connections between them. When I naturally tried to just remove the unwanted label, it removed all of them, including the one on the input wire.
Thank you!
Re: How to draw bridged 3way or 4way terminal blocks
i did it for this Terminal like this:
https://qelectrotech.org/forum/misc.php … mp;preview
Seeing the red terminal line inside the circle, are you somehow using the built in terminal block symbol or did you create your own?
Yeah im using this
https://qelectrotech.org/forum/viewtopic.php?id=2938
