Topic: NO_PUBKEY BC9F825E1D4FB6C1 - Download for Debian Bookworm
When appending
deb https://debian.qelectrotech.org/qet/builds/debian stable main
to /etc/apt/sources.list and
$ apt update
i get this error message: NO_PUBKEY BC9F825E1D4FB6C1
Furthermore i get a warning that apt-key is deprecated.
How do i install the latest stable QElectrotech under Debian bookworm?
Re: NO_PUBKEY BC9F825E1D4FB6C1 - Download for Debian Bookworm
https://qelectrotech.org/wiki_new/doc/install_debian
This is wher I begun, but already the command
gpg --verbose  --keyserver pgpkeys.mit.edu --recv-key 1D4FB6C1
fails with
gpg: Server indicated a failure
Try
wget -q -O - https://debian.qelectrotech.org/qet/builds/debian/Qelectrotech_Repository.asc | sudo apt-key add -
For the record and users who run Debian GNU/Linux unstable:
apt-key is not available in Debian unstable anymore!
For a few days now, this is the way to go:
  • download key-file:
    wget -q https://debian.qelectrotech.org/qet/bui … sitory.asc
    and save (as root) to /etc/apt/keyrings
  • adjust sources-list entry for QElectroTech
    file needs the ending ".sources" as in this example:
    /etc/apt/sources.list.d/qelectrotech.sources
  • content of qelectrotech.sources:
# draw electric diagrams with QElectroTech
Types:      deb
URIs:       https://debian.qelectrotech.org/qet/builds/debian/
Suites:     unstable
Components: main
Enabled:    yes
Signed-By:  /etc/apt/keyrings/Qelectrotech_Repository.asc
  • from here everything further is known:
    apt update
    apt install qelectrotech
@scorpio810:
Maybe you can update the information on QET-Homepage, Laurent?
Thanks in advance!  nomicons/smile
Strange, again?
see --> Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details
https://qelectrotech.org/wiki_new/doc/i … or_details
Perhaps because the system was installed a long time ago and has only been updated since then?
In any case: The qelectrotech.sources described above also works with Debian Bookworm.
I get this now: NO_PUBKEY B8D8B0B00ADD2851
(debian stable repo)
Thanks.
Err:16 https://debian.qelectrotech.org/qet/builds/debian stable InRelease
  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY B8D8B0B00ADD2851
Fetched 45.8 kB in 2s (29.3 kB/s)
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY B8D8B0B00ADD2851
I'm also receiving this message recently
GPG error: https://debian.qelectrotech.org/qet/builds/debian stable InRelease
System:
  Kernel: 6.12.12+bpo-amd64 arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
  Desktop: Cinnamon v: 5.6.8 tk: GTK v: 3.24.38 wm: Muffin dm: LightDM Distro: Debian GNU/Linux
    12 (bookworm)
  Active apt repos in: /etc/apt/sources.list.d/qelectrotech.list
    1: deb [signed-by=/etc/apt/trusted.gpg.d/Qelectrotech_Repository.asc] https: //debian.qelectrotech.org/qet/builds/debian stable main
Please no further messages, that there are error-messages on apt-update:
Our Developer and Debian-Packager is in poor health and therefore it will take some time until the problem will be solved.
The key file has recently been renewed, see the plc user article on how to use it:
https://qelectrotech.org/forum/viewtopi … 890#p20890
BTW, Pysimplegui and qet_tb_generator were rebuilt for the new keyfile and uploaded back into the QET Debian stable and unstable repositories.
For me it solved the error.
Thank you very much.
Thank you very much. I could install new version by downloading the asc key and creating the sources file BUT, related to the repository configuration file, two points:
1) My system is Debian stable, multiarchitecture and sudo apt update complained about missing i386 architecture in qelectrotech repository. The solution to that is adding a line with just the Architectures directive:
$ cat /etc/apt/sources.list.d/qelectrotech.sources
Types:      deb
Architectures: amd64
Suites:     stable
Components: main
Enabled:    yes
2) Debian (bullseye) stable (and also backports) have version numbers higher than the reported by qelectrotech deb packages at debian.qelectrotech.org (debian versions are 1:0.9-1 and 1:0.9-1~bpo11+1). To be able to install latest version, I've had to uninstall Debian version and force installation of 0.100.0.r8447-2.
Regards and thanks for your time,
Josep
Thanks all for report  feedback.
Yes Josep you are right I removed i386 arch and now you need to add Architectures: amd64 in /etc/apt/sources.list.d/qelectrotech.sources
2) use pinning to force 0.100-dev versions:
sudo echo -e 'Package: qelectrotech* \nPin: version 0.100.* \nPin-Priority: 1001' > /etc/apt/preferences.d/40qelectrotech-devel
https://qelectrotech.org/wiki_new/doc/i … an_pinning
Thanks.
I could not use your command from a normal user as redirection > is not run as root (sudo applies only to echo command). One solution is to use tee:
echo -e 'Package: qelectrotech* \nPin: version 0.100.* \nPin-Priority: 1001' | sudo tee /etc/apt/preferences.d/40qelectrotech-devel > /dev/null
Thanks for all,
Josep
FYI, I upgraded my pbuilder for make deb stable bullseye to last stable aka: Trixie in my Debian repository.
Qt 5.11.3 -> Qt 5.15.15...
So if you are on Debian bookworm please upgrade to latest stable Trixie, enjoy! nomicons/wink
No changes for Debian Unstable debs!
FYI, for Debian stable Trixie I rebuild Pysimplegui and qet_tb_generator debs.
(no changes)
Enjoy! nomicons/wink
https://download.qelectrotech.org/qet/b … simplegui/
https://download.qelectrotech.org/qet/b … generator/
