Topic: NO_PUBKEY BC9F825E1D4FB6C1 - Download for Debian Bookworm
When appending
deb https://debian.qelectrotech.org/qet/builds/debian stable main
to /etc/apt/sources.list and
$ apt update
i get this error message: NO_PUBKEY BC9F825E1D4FB6C1
Furthermore i get a warning that apt-key is deprecated.
How do i install the latest stable QElectrotech under Debian bookworm?
Re: NO_PUBKEY BC9F825E1D4FB6C1 - Download for Debian Bookworm
https://qelectrotech.org/wiki_new/doc/install_debian
This is wher I begun, but already the command
gpg --verbose  --keyserver pgpkeys.mit.edu --recv-key 1D4FB6C1
fails with
gpg: Server indicated a failure
Try
wget -q -O - https://debian.qelectrotech.org/qet/builds/debian/Qelectrotech_Repository.asc | sudo apt-key add -
For the record and users who run Debian GNU/Linux unstable:
apt-key is not available in Debian unstable anymore!
For a few days now, this is the way to go:
  • download key-file:
    wget -q https://debian.qelectrotech.org/qet/bui … sitory.asc
    and save (as root) to /etc/apt/keyrings
  • adjust sources-list entry for QElectroTech
    file needs the ending ".sources" as in this example:
    /etc/apt/sources.list.d/qelectrotech.sources
  • content of qelectrotech.sources:
# draw electric diagrams with QElectroTech
Types:      deb
URIs:       https://debian.qelectrotech.org/qet/builds/debian/
Suites:     unstable
Components: main
Enabled:    yes
Signed-By:  /etc/apt/keyrings/Qelectrotech_Repository.asc
  • from here everything further is known:
    apt update
    apt install qelectrotech
@scorpio810:
Maybe you can update the information on QET-Homepage, Laurent?
Thanks in advance!  nomicons/smile
6
Strange, again?
see --> Key is stored in legacy trusted.gpg keyring (/etc/apt/trusted.gpg), see the DEPRECATION section in apt-key(8) for details
https://qelectrotech.org/wiki_new/doc/i … or_details
7
Perhaps because the system was installed a long time ago and has only been updated since then?
In any case: The qelectrotech.sources described above also works with Debian Bookworm.
