Topic: Text Box With Rounded Corners
Hello friends
What I want to do is add a text box. However, the edges of the frame should be rounded. Same as below:
Element.png: Edit The Element -> Text -> Property -> Frame
Text.png: Add A Textfield
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0//EN" "http://www.w3.org/TR/REC-html40/strict.dtd">
<html><head><meta name="qrichtext" content="1" /><style type="text/css">
p, li { white-space: pre-wrap; }
</style></head><body style=" font-family:'STIX Two Text'; font-size:9pt; font-weight:400; font-style:normal;">
<table border="1" style=" border-color:#000000; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; border-collapse:collapse;" cellspacing="2" cellpadding="0">
<tr>
<td>
<p style=" margin-top:5px; margin-bottom:5px; margin-left:5px; margin-right:5px; -qt-block-indent:0; text-indent:0px;">QElectroTech</p></td></tr></table></body></html>
Whatever I did in the code above did not work or I lack information.
I would appreciate your help. Thank you very much.
Re: Text Box With Rounded Corners
QElectroTech uses the RichText-Editor from Qt for Text-Fields.
"border-radius" is supported by plain html / css but not in RichText-Editor of Qt:
See here: https://doc.qt.io/qt-6/richtext-html-subset.html
As a workaround you may create an element with a rounded rect, place it in diagram and place a free text above it in diagram-editor...
Thank you @plc-user for your quick response. It helped me.
