Re: New .dxf to .elmt Conversion Program
Hallo plc-user,
plc-user wrote:
I noticed something similar with the imperial DXF from your American compatriot.!
I can double check, but I believe this extra scaling factor for the imperial unit drawing was fixed in the last commit.
plc-user wrote:
If we focus on the 20 mm font:
In LibreCAD (black background) it is good to see that both texts are the same size - I expect the same for the element.
In the element (white background), the polygon 20 mm are 40px high, but the 20 mm text has a font size of 57.
So there is still a factor of about 1.4 somewhere in there that doesn't belong.
The scaling for the font is handled separately from the rest of the drawing. This is because dxf stores text height in whatever unit the drawing is in (ie mm, inches, etc) and QET uses your stand font points. A font point is defined as 1pt = 1/72 inches, which comes out to 1pt = 0.3528mm.
Based on this conversion the values that are being generated are "correct", because text height in mm would be multiplied by a factor of roughly 2.83. instead of the 2 used to convert mm to pixels.
I checked a couple of online unit conversion calculators to verify my math and 20mm comes out to 56.692913386pt font, rounded to 57 in the element.
You are right though that this clearly isn't correct in the element file. Doing a quick hacky test of modifying the text element font size to try and match the polygon size, it looks like the factor in your sample file should be 2.1. (for the 20mm text, a font size of 42pts).  It's not clear to me where this 2.1 comes from...but it is close to the 2px per mm we use in the conversion of this drawing. Perhaps multiplying the text height in real world units by the same as the rest of the drawing instead of "properly" converting between font points and real world units would be better? I'll need to try and do more testing and see what I can come up with, and test it against some other drawings.
My health is deteriorating and I find it hard to think and organise myself.
Laurent,
I'm sorry to hear about your health, and I hope you get better.
I wish I had more time to contribute and help out with QET, but I have young children which for the moment take a lot of time and energy.
Hello vadoola,
vadoola wrote:
(...) A font point is defined as 1pt = 1/72 inches, which comes out to 1pt = 0.3528mm.
Just to understand you correctly:
You think the calculation of the text size is correct if a text that fits well into a rectangle in the DXF is much bigger and no longer fits into the same rectangle in the converted element? And that's because it says somewhere that a px is not as big as a pt? Seriously?
Attached is another example to clarify what I mean:
A DXF file in which I have inserted an 11 mm high text into a field of about 12 mm. Next to it is the converted element file, where you can see that the text “11 mm” definitely does not fit into the same field. In addition, the element file in which I changed the text “11 mm” to the appropriate size “22” and moved it.
I am explicitly not talking about the text position here, as we both know that this does not yet fit: I'm talking about the text size!
Note:
I used dxf2elmt - sources from last weeks commit c3a5b2a.
Attachment icon Bildschirmfoto_20250129_001_LibreCAD.png 6.68 kb, 71 downloads since 2025-01-29
Attachment icon Bildschirmfoto_20250129_002_converted_by_dxf2elmt.png 9.24 kb, 58 downloads since 2025-01-29
Attachment icon Bildschirmfoto_20250129_003_Textsize_and_Posittion_corrected.png 11.03 kb, 71 downloads since 2025-01-29
Hallo plc-user
I think I worded things in a way that did not translate properly for someone who is not a native English speaker. Sorry about that, I will try and word things better to make it more clear.
The current code is my first attempt and properly handling the text sizing, and text scaling over what Antonio had with just a fixed 12pt font. I based the conversion of the text size from real world units (which the text height is stored as in dxf) to font points using the defined definition of 1pt = 1/72 inch. In the couple of drawings I tested this scaling looked OK, but I knew it needed more testing and verification. I checked it in because it was already better than what was there. Perhaps I need to do a better job and work at some of these features in branches instead of on master so people don't think the checked in code is fully functional, however you testing against it and provided these files is very useful feedback for me to fix problems.
When you brought this up and provided the Schriftgroessen file I checked against some online calculators converting mm to pt to verify that I had done the math correctly in my code. Based on the conversion of 1pt = 1/72 inch, I did do the match correctly in my code, but this conversion factor clearly does not provide good results, after testing against some more files.
So the question is what conversion factor do I need to use? In the Schriftgoessen file you provided, if I had assumed that 1mm  = 1pt and then scaled it with the mm->px conversion of 2x, that actually would have been more accurate. It looks like it actually should be converted by a factor of 2.1, but 2 would have been closer than 2.8 used based on the mm->pt conversion I used. What I need to figure out is that roughly 2x height to pt conversion in the Schriftgroessen file something that could be valid or just coincidence in the factors similar?
Perhaps a better method here is assume that 1 unit (based on the file, mm, inches etc) is equal to 1pt and then scale based on the 1mm = 2px, perhaps I should always assume 1mm = 1pt, and then scale. I'm not really sure, I'll need to do more testing to try and narrow down what the right scaling factor might be, and need to make sure I'm testing against multiple units.
I think the next step for me to do is create a handful of files along the lines of Schriftgroessen but in several units like inches, ft, cm, etc and do some testing to try and narrow down a more accurate scaling factor.
Hopefully that makes things a bit more clear.
Hello vadoola,
let's put it this way:
I created a QET-Element just with the use of element-editor.
In the attachment you see, that the texts are the same size as the height of the rectangles.
So in my opinion we do not have to use another factor than 2.0 for the "real world" size in the DXF!
When DXF says circle has a diameter of 10mm then in element it is 20.
If it says 1 inch in the DXF it will be 50.8 in the element whether it is a graphical part or a text!
It does not matter if text or anything else: There is always a "scale" of 1mm = 2px
I checked in all DXFs I have: Fits everywhere!
If you have a DXF where the factor of 2.0 does not fit: Let me see.
Attachment icon Bildschirmfoto_2025-01-29_textsizes_in_QET.png 54.08 kb, 69 downloads since 2025-01-29
If you look at the “imperial” DXF from last week:
Which one matches the original sizes better?
I know that we won't be perfect with text-size, because for elements we have to round to integer numbers, but I think we should be as close to the original as possible!
Attachment icon Bildschirmfoto_2025-01-29_001_LibreCAD.png 4.92 kb, 60 downloads since 2025-01-29
Attachment icon Bildschirmfoto_2025-01-29_002_converted_with_original_dxf2elmt.png 51.77 kb, 67 downloads since 2025-01-29
Attachment icon Bildschirmfoto_2025-01-29_003_converted_with_modified_dxf2elmt.png 49.06 kb, 63 downloads since 2025-01-29
I think I see the confusion.
QET says it's measuring the font size in pts...but pts and pixels are not the same. Based on the file you just provided  (textsizes_in_QET.elmt) QET is actually storing the text size in pixels not points, despite it being labeled as in points. (I don't know if this is the case in all languages, or perhaps a mistranslation in the English text for QET). If that is the case, then you are correct that using the exact same scaling factor as the rest of the drawing should be accurate, since the text sizing is not stored how I though it was based on how QET labels it.
I'm taking a closer look now that I'm on my lunch break, and it looks like I'm completely wrong about QET saying the font is in pt's. Nowhere does it say that, it simply refers to it as size. It's just so common for font to be stored as pt's instead of pixels I must have just assumed size meant font points instead of pixels. I clearly made a mistake here, downside of squeezing in time when I can even if that means I'm a bit distracted or tired. I'll try and find some time to get the code updated to scale the text correctly.
Hello vadoola,
It's good that we agreed on the scaling after all! I knew there was a misunderstanding somewhere... but didn't see
Sometimes I have to read the documentation and comments in the source code several times, too: the language barrier (French, English, German, ...) is sometimes quite high and with sharp edges! nomicons/wink
Take your time for the realization!
As we say in German: "Gut Ding braucht Weile!"
‘Good things take time!’
@vadoola:
As also discussed in the other thread:
We are about to ship a few free fonts with QET. Among them is “osifont” which is often used as a font for CAD applications.
What do you think about specifying “osifont” as a font in converted elements for which no font is specified in the DXF?
When I look at the title block of the well-known “Wet Location Grip” file in LibreCAD and compare the font with “osifont” in QET, the font fits much better than a sans serif font.
Would like to have attached a screenshot, but something's still wrong with forum-settings: I cannot attach a file!
missing attachment
osifont is a good decision, especially if it is used by other Card-Software. The DXF Export Function of QelectroTech is very important and a lot of users need it.
You're already now free to use any font you like, RedBaron!
If you need osifont for your elements and schematics: use it!
BTW: This part of forum is about import of dxf to elements.
Thank you for clarification.
plc-user wrote:
@vadoola:
I've never heard of IS0 3O98, it looks like it's mostly a European thing, but it looks similar to other fonts I've seen used by AutoCad even outside of the Europe. I agree based on that screenshot you sent it does look a lot closer to what is being used by CAD that the Sans Serif font. Setting the default to "osifont" should be pretty straight forward. I'll see if I can do it tonight.
Salut Laurent, Hallo plc-user,
And to anyone else willing to help out.
I created a branch to try and finish up on the issues with nested blocks: https://github.com/Vadoola/dxf2elmt/tree/nested_blocks, as originally brought up at https://qelectrotech.org/forum/viewtopic.php?id=2890
While there are still some minor issues (like text positioning but that's not exclusive to blocks), so far in my testing with a few files it seems to be pretty good.
If anyone has some good dxf files with nested blocks they want to test against let me know. I'll try and wrap up some of those minor issues, and merge it back into the main branch soon.
Hello vadoola,
the file pxc_2700975_11_00_ILC-171-ETH-2TX_2D.dxf from Phoenix Contact seems to be a real challenge!
When converting exploded drawing from LibreCAD, the controller is found outside the drawing-area of the A3-sheet.
It is (of course) copyrighted, so no re-distribution here: --> Downloads --> Technische Zeichnung
plc-user wrote:
Hello vadoola,
Thanks I'll take a look at it.
Wow...2.8MB that's a big dxf, Looks like it has a whole lot of blocks. Should be a good test drawing to find some deficiencies in dxf2elmt hopefully.
I know it's been a while since I've been around. I hope everyone is doing well. I've had a lot going on, as well as a few injuries unfortunately that slowed down development for a bit.
There could be some other issues with it still, but I'm pretty happy with the nested block support as it stands currently. As there were a fair number of changes for this support, plus other things that have changes since the last release was cut, I decided it was worth marking as a new release. So version 0.5.0 was released about an hour ago.
Let me know if you find any specific issues with it.
Hi vadoola!
Good to hear, you're ok (again)!
Can you please create win- and/or Linux-Binaries for dxf2elmt and put them also into the release at github?
So everyone gets the Software from "first hand"!
plc-user wrote:
Hi vadoola!
Yeah, I have no experience or familiarity with Github CI. I've been trying to hobble something together by copying how some others have done it, and have been completely unsuccessful. I probably need to set aside some time to sit down and learn it properly. The hope of course is that I can get it set up, and when a release is made CI will generate the binaries and attach them to the release.
For this release it will probably be faster and easier to just manually create them myself and get them uploaded.
Linux Debian unstable binary
macOS arm64 binary
Btw, it's run well only CLI on terminal, on GUI import DXF segfault...
thread 'main' panicked at src/main.rs:65:58:
called `Result::unwrap()` on an `Err` value: Os { code: 30, kind: ReadOnlyFilesystem, message: "Read-only file system" }
note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
macOS arm64 binary
Are you only getting that on the Mac? Or on other machines too? It's interesting that it's only happening when being called from QET and not from the CLI.
Either way I see what the issue was. I finally added a bit of logging trying to troubleshoot some issues with the nested blocks. A bit of poor error handling on setting up the logging slipped through to the release....ah actually I think it makes sense now depending on exactly how you are running it. By default it just creates a dxf2elmt.log file in the same folder as the exe. If you have write permissions on the folder when running it from the CLI, no problem. If it doesn't have write permissions for the folder where the plugin is run from it will probably get that ReadOnlyFilesystem error, and then the poor error handling for the logging file is causing it to panic and halt execution. I'll see if I can get a bug fix release out shortly.
Do you know what the typical logging system on MacOS is? On Linux of course you have syslog, or the systemd journal. Windows you could use the Event System....The last Mac I used consistently was PowerPC based, so I don't really know the system well now. Trying to figure out what options I have for logging other than just creating a log file.
