Topic: Créer une bobine maître
 Bonsoir,
j'ai voulu créer une bobine clignoteuse qui ne figure pas dans la liste de choix, en modifiant une bobine maître existante.
La bobine semble avoir perdu ces capacité de maître.
Quand j'ouvre le fichier elmt avec un éditeur de texte:
<definition width="60" version="0.4" hotspot_x="25" hotspot_y="30" height="60" type="element" ic="true" orientation="dyyy">
    <names>
        <name lang="en">Flasher relay</name>
        <name lang="fr">Relais clignoteur</name>
    </names>
    <informations>License: see http://qelectrotech.org/wiki/doc/elements_license</informations>
    <description>
        <rect width="7" x="-22" y="-10" antialias="false" height="20" style="line-style:normal;line-weight:normal;filling:none;color:black"/>
        <rect width="30" x="-15" y="-10" antialias="false" height="20" style="line-style:normal;line-weight:normal;filling:none;color:black"/>
        <line length1="1.5" length2="1.5" antialias="false" end1="none" end2="none" style="line-style:normal;line-weight:normal;filling:none;color:black" y1="20" x1="0" y2="10" x2="0"/>
        <line length1="1.5" length2="1.5" antialias="false" end1="none" end2="none" style="line-style:normal;line-weight:normal;filling:none;color:black" y1="-20" x1="0" y2="-10" x2="0"/>
        <input x="-14" y="18" size="4" text="A2"/>
        <input x="-14" y="-17" size="4" text="A1"/>
        <input x="16" y="0.5" size="9" text="_"/>
        <line length1="1.5" length2="1.5" antialias="false" end1="none" end2="none" style="line-style:normal;line-weight:normal;filling:none;color:black" y1="1.42222" x1="-20" y2="-1.46667" x2="-20"/>
        <line length1="1.5" length2="1.5" antialias="false" end1="none" end2="none" style="line-style:normal;line-weight:normal;filling:none;color:black" y1="-2" x1="-20" y2="-2" x2="-17"/>
        <line length1="1.5" length2="1.5" antialias="false" end1="none" end2="none" style="line-style:normal;line-weight:normal;filling:none;color:black" y1="-2" x1="-17" y2="-5" x2="-17"/>
        <line length1="1.5" length2="1.5" antialias="false" end1="none" end2="none" style="line-style:normal;line-weight:normal;filling:none;color:black" y1="2" x1="-20" y2="2" x2="-17"/>
        <line length1="1.5" length2="1.5" antialias="false" end1="none" end2="none" style="line-style:normal;line-weight:normal;filling:none;color:black" y1="2" x1="-17" y2="5" x2="-17"/>
        <terminal x="0" y="-20" nameHidden="0" number="" name="" orientation="n"/>
        <terminal x="0" y="20" nameHidden="0" number="" name="" orientation="s"/>
    </description>
</definition>Faut-il rajouter :
<kindInformations>
                    <kindInformation name="state" show="1">NO</kindInformation>
                    <kindInformation name="number" show="1">1</kindInformation>
                    <kindInformation name="type" show="1">tempo</kindInformation>
                    <kindInformation name="tempoType" show="1">work</kindInformation>
</kindInformations>Alexis
