Topic: Convert DXF-->QET
Hello Everyone ,
I have a problem with converting DXF file to QET. I'm using "DXFtoQET" for converting DXF file, everything looks good, so program create for me the file in my depository C...get/elements (see photo1). Furthermore, I have also seen this in QET on my “user collections” (see photo2). Unfortunately, I can't use this in the program, could somebody follow me what I'm doing wrong ??
Best regards Michal
Im using QUT ver  V 0.100.0-dev
Photo_1.png, 24.6 kb, 902 x 427
Photo_2.png, 15.58 kb, 510 x 301
Re: Convert DXF-->QET
What do you mean with "can't use it"?
An element with the name 942315m is in the user-collection.
So just pull it onto the schematic!
Can you open the element in Element-Editor by double-clicking?
Then save it before trying to use it in Circuit-Editor.
Maybe the use of dxf2elmt results in a better element?
Give it a try...
It's my mistake, I download incorrect dxf file … Learning by doing nomicons/smile now working properly!
BR Michal
4 (edited by eya 2025-02-22 10:41:13)
i have problem too ; when i try to convert the dfx file ; with DFXtoGET i can see the elmt file it shows it to me ; but when i try to reach it without the app there is nothing!
Capture d'écran 2025-02-22 093626.png, 2.9 kb,  x
image_2025-02-22_094107933.png, 12.32 kb,  x
Hello eya,
If the file-browser of converter shows the file, it should be found by other file-browsers, too...
What version of QElectroTech do you use?
Version 0.9 is a bit outdated in the meantime ... I recommend 0.100-dev
And it is very recommendet to use dxf2elmt instead of something else!
In current versions of QET there is a menu-entry in Element-editor to import a dxf with dxf2elmt.
Then you don't have to handle converted files, but can work with QET alone.
Vadoola, the current author of dxf2elmt, released new sources today.
I guess you run win? In the attachment you find the compiled binary.
and here is the Linux-version
Salut Laurent, Hallo plc-user
Since it's unlikely that Antonioaja will be working on dxf2elmt going forward and and my fork has diverged quite a bit at this point, I was considering on disconnecting my fork from his. I still plan on giving him full credit for the work he did, and will update the Readme to link back to his repo, I just wanted to separate the fork.
There are some things I need to consider, I thought I saw somewhere that it might ruin any issues you have, but I'm not sure. Either way in order to separate it from Antonio's fork my repo can't have any fork's itself. Would you two be willing to delete the forks you have made from my repo so I can separate it from Antonio's? Then you can refork it if you need to.
Hello Vadoola,
no problem for me: Already deleted my fork!
Hello Vadoola,
same here: Already deleted my fork!
