Topic: Elements Schneider
savez-vous si un contributeur à réaliser l'ensemble des éléments Schneider Resi9 XE ou XP ?
J'ai fais mon tableau avec les éléments Legrand (merci aux contributeurs), cependant si il existe un bibliothèque Schneider, je suis preneur.
Merci
Re: Elements Schneider
ayant monté moi aussi en rénovation chez moi un tableau en Schneider Resi9 XE 4 rangées je n'ai rien trouvé dans nos collections du moins en  Resi9 XE ..., par manque de temps je me suis rabattu (chut, faut pas le dire, uhu) chez schneider qui propose un logiciel qui te permet d'imprimer le schéma de principe de ton tableau ainsi que la mise en place, et d'imprimer les étiquettes de repérage.
https://download.qelectrotech.org/qet/e … index.html
https://download.qelectrotech.org/qet/forum_img_2/edisign_laurent.png
Why do you recommend contrib-elements, when we have so many parts from different manufacturers in official collection, Laurent? nomicons/wink
All Schneider-parts from contrib are also available in official collection!
Bildschirmfoto_2025-02-10_Installation.png, 51.47 kb,  x
Hallo plc-user,
The two repositories and collections are complementary. nomicons/wink
you may need to search both collections...
See history commits
https://github.com/qelectrotech/qelectr … mits/main/
And first commit:
https://github.com/qelectrotech/qelectr … 992ea2db6e
Salut Laurent !
I do not like to contradict you, but the elements of the mentioned manufacturer and sub-dirs are identical in both collections!
Some elements seem to be edited using a text editor in order to add translations, while the element editor was used for the additional translation in a few cases.
And one subdirectory has been renamed.
Some of the elements in the official collection should be revised because, for example, the aspect ratios and scaling do not fit. Let's see if I can find some time for this...
6
Hallo plc-user,
It's my fault, I saw later that the files in the two collections directory and folder were identical. nomicons/cwy
This is the best way of adding translations so far, without the svn/git differences being inflated by the hazardy registration of xml attributes since Qt 5X.
7
Salut Laurent !
It's not about fingerpointing here! nomicons/wink
Another reason to try to sort arrtibutes in element-file.
That's why valoola and I should use the same order for attributes in output of dxf2elmt and QET_ElementScaler. Seems that we do...
8
Good to know that we do, it was completely accidental, I mostly just stuck with the same general ordering of attributes Antonio was using in the original version. I'll try to make sure it stay's in sync with what QET_ElementScaler does.
