1 (edited by xgn 2025-01-17 09:52:05)
Topic: Two different potentials wiring keeping unique text
Hello,
Is it possible, or what solution could be, if it is needed to wire two (or more) different potentials (while referencing folios with coming/going arrows) into one connection point (e.g. double terminal block) but keeping unique/independent wire texts. E.g. when splitting from one terminal block into several separate DAQ measurement channels. Now when connected directly using wires or joints, or splices, it automatically overrides all connected wires' texts according to the latest connection.
Thanks if anyone could suggest solution to solve this.
2 (edited by plc-user 2025-01-17 10:51:39)
Re: Two different potentials wiring keeping unique text
You mean something like a Bus or a cable like in the attachment?
As far as I know a bus cannot be defined but sometimes I read something like "define a cable" in the forum what might be similar...
Try forum search.
Hello
if you using wires or joints, or splices, drag and drop official symbol to your custom collection, open it in element editor and change the type of your element   "terminal" to "simple" or create a new symbol from scratch and select type "simple".
Element with "terminal properties" keep equipotentiality. Same for element report folio!
4 (edited by xgn 2025-01-17 12:34:54)
Thanks for reply.
Yes, like bus or more simple - just two different wires going into one connection point but keeping unique texts.
E.g. as shown in the image where going arrows reference two different measurement channels and would like to have different text1 and text2
5 (edited by xgn 2025-01-17 14:14:32)
Hello
Haven't seen your reply. Thank you, I will give a try!
Update:
Yes, working!
