Topic: too many dashed lines looks like solid line
Hi there! I'm a electrician student and I just found this software and it's awesome!
One question: when I connect many wires into one endpoint, too many dashed lines overlies each other and it looks like one solid line. How can I make it look all the way dashed? I hope you understand.
Thank you very much!
Re: too many dashed lines looks like solid line
Hello, to ensure that multiple dashed lines don't overlap and appear as a solid line when connecting wires to one endpoint, I think you can try adjusting the line properties or using appropriate layering techniques
You can use element to do that: your element or from library. See picture.
4 (edited by JermainOkuneva99 2024-11-20 03:04:27)
I think a good solution is to tweak the line properties or use other display elements from the software library. Geometry Dash Scratch
