26 (edited by plc-user 2024-10-16 07:21:31)
Re: dxf2elmt
Kellermorph wrote:
Here is the dwg.
i tried it with https://download.qelectrotech.org/qet/b … .0/win_64/
Nö!
Unter dem Link ist das (inzwischen veraltete) Konvertierungsprogramm zu finden.
Es geht um die dxf-Dateien, die Du konvertieren möchtest!
Du schreibst, dass Fehlermeldungen auftreten, oder eine leere Zeichnung aus der Konvertierung herauskommt, lieferst aber die dxf nicht mit, die uns helfen würden, dir helfen zu können!
Re: dxf2elmt
Oh ich hatte vergessen auf "Add File" zu drücken entschuldige.
Re: dxf2elmt
Error: Failed to load deos600...
    Make sure the file is a valid .dxf file.
Caused by:
    an unexpected code '90' was encountered at line/offset 11
/media/backup6/download$ cat -b deos600.dxf
     1      0
     2    SECTION
     3      2
     4    HEADER
     5      9
     6    $ACADVER
     7      1
     8    AC1032
     9      9
    10    $ACADMAINTVER
    11     90
    12           55
    13      9
    14    $DWGCODEPAGE
    15      3
    16    ANSI_1252
    17      9
    18    $LASTSAVEDBY
    19      1
    20    Thomas16
    21      9
    22    $REQUIREDVERSIONS
    10    $ACADMAINTVER
    11     90
See:
https://github.com/ixmilia/dxf-rs/issues/46
https://github.com/ixmilia/dxf-rs/issues/27
https://ezdxf.mozman.at/release-v0-10-1.html
But if I open with libreCad and save the DXF in ‘drawing Exchange 2007’ format (*.dxf)... Vadoola dxf2elmt works but ... the font size was too big, it's a good start. nomicons/wink
Edit: no need to open with LibreCAD just remove these lines (10 to 13):
    10    $ACADMAINTVER
    11     90
    12           55
    13      9
https://download.qelectrotech.org/qet/forum_img_2/dxf2elmt_error8.png
Re: dxf2elmt
In the XML of the elmt file produced by dxf2elmt, I was able to easily separate the drawing data from the text data in order to create two QET symbols so that I could try to merge them manually from the editor.
It is not easy to adjust the text fonts on the drawing, which is why in a symbol of this type with a lot of text and terminals, it is preferable to draw it from the editor from scratch.
Re: dxf2elmt
I tried lastest Vadoola commit: 4ecce24
Better improvement for this DXF file. nomicons/wink
https://download.qelectrotech.org/qet/forum_img_2/new_dxf_vadoola1.png
https://download.qelectrotech.org/qet/forum_img_2/new_dxf_vadoola2.png
