Topic: Different wires connected to the same terminal
Hello everyone,
I'm probably taking the wrong approach.
I have problems with the properties of the wires. When I have multiple wires of different sections starting from a terminal, if I set the properties of a wire these are also assigned to all the other wires.
The name, voltage, etc, obviously must be the same but the section could be different.
I saw the "Apply properties to all conductors of this potential" flag but if I uncheck it, change the properties and enter it again it is enabled again (tried with 0.100.0-dev and 0.90).
Am I doing something wrong?
I attach an example.
Thank you.
