Topic: QET-Element to SVG
Salut Laurent et Joshua,
hello everyone,
based on the Idea of QET_ElementScaler I created a first version of a converting-tool in C++.
Some graphical elements already work very well, like RECT, ELLIPSE. POLYGON, ARC.
Not working: Line-Endings like Bullets or Arrows – they are not defined in SVG and have to be drawn separately.
What is a problem since I've been using Computers and Operating-Systems: Fonts!
So for now only static Texts are basically implemented with limitations: no rotation and the font is saved as "Sans Serif".
Another topic we should discuss are colors. Of course it is very useful for the user to have Names of colors in the GUI. But when I use the given names of the colors in SVG most of them aren't defined and some look different: "green" in QET is much lighter than "green" in SVG. So I had to implement a translation-table from the color-names to RGB-values which work very well in SVG.
Maybe we should use RGB-values instead of color-names in QET-Elements, too? Then the colors would be defined exactly.
And: Do we really need more than 150 named colors in QET where many of them are duplicates like "red"/"HTMLRedRed" or "cyan"/HTMLCyanAqua"/"HTMLCyanCyan" which represent the same RGB-values when I look at the color-table here: https://doc.qt.io/qt-6/qml-color.html?
In the attachments you find a sample-element and the resulting SVG.
I would like to use this thread to discuss the further details of the software with the developers of QET.
Best regards,
plc-user
