Topic: Copying/Moving some connection to other folio - loosing information
Hi
Maybe I use it wrong. And I've looked through old topics, but found nothing corresponding my problem.
And, the program is a huge help for me - it works fantastic. So let me say "thank you" at this point!
Please see this only as suggestion.
I have some connection path (I don't know how to name it correct, in german I would say "Abgang") on, let's say folio 3.
I want to move the whole connection path to folio 2.
-> select, STRG-X on folio3, STRG-V on newfolio.
It works in principle but on new folio, I loose some information like
- labels
- annotation
Other informations remain, like
- Function
- Auxiliary block 1&2
- Plant
- ..... maybe some more - I didn't try all
When I copy this, of course "Label" has to be set new (no same name possible), but maybe all other information fields can stay?
But when moving, keeping all information (including LABEL) would be good.
Or did I use it in a wrong way?
Thank you, Andi
using on Linux Mint 20.2 Cinnamon
QElectroTech_0.100.0-r7986-x86_64.AppImage
Re: Copying/Moving some connection to other folio - loosing information
https://download.qelectrotech.org/qet/manual_0.7/build/_images/qet_configure_project.png
Un check the fisrt option.
Whow, thank you.
I didn't see that - sorry.
Thank you very much.
Warnings: keep labels when your copy, but if you have links, like master/slave, or reports you need to linking again.
