Topic: How to update/refresh the drawing after element was edited
Hello Al
I have a maybe silly question:
If I have an element and I wanna edit it in the editor, e.g. change the size, I can do that,
save the element close the editor, but nothing happens.
The element on the folio keeps the same size.
What must be done to update the drawing? I think reopen the project can do that, but
I don`t wanna always close and reopen the file.
Thanks for help.
Regards
Chris
Re: How to update/refresh the drawing after element was edited
Hello Chris,
drag abd drop your element modified and saved before close QET.
Regards
Hi Laurent
Yes, this I could see, but if I wanna modify the element somewhen later during the design phase, and I have
for example some texts attached to the element, I have to make all the texts from scratch?
It`s as if I would place a complete new element.
Delete the old one, insert a new one, and make all things new?
Regards
Christian
Hello once again
This all doesn`t work as expected.
Today I insert a switch. Is too small. OK, modify the component. Done.
Delete old one, insert new one, but I don`t get a message if I wanna replace the already insert
parts? I just can insert a new one.
And I have a Auto-numbering. So each time I insert a part the index is incremented.
Means, if I change 5 times the size, at the end I have only one part with index 5.
Thanks for help how I can manage this correctly.
Chris
Hi C.lehner,
I fall on same issue, and I found half answer.
1) You must update (edit) your user/company collection symbol, never the local project symbol. So when you try to place one more from there you get the message your local project collection will be update.
2) I think on previous process you don't even need to place one, you just need to drop and down and click yes for library update.
3) I found already installed old symbols are not updated till project is closed and open again. Sorry I am novice and I don't know if there is another way to force to update all proyect.
Note: I miss the option to update only the collection you have modified and full collections updated is required when a new symbol is added (even from symbol manager tool "save as file" command).
