Topic: Jump Element
Hello, I seem to be having a problem with how the jump element works. When I add the jump element, all the lines are crossed instead of having the space between the arc, am I missing something?
QElectroTech → EN : Help, suggestions, discussions, ... → Jump Element
I believe the problem is that I can't seem to connect a regular line to the jump connection
first drag your jump and if autoconnect is enabled the second jump vertically in the same alignment is connected by conductor.
That worked, thank you.
Great ! ;-)
Generated in 0.029 seconds (22% PHP - 78% DB) with 11 queries
