Topic: The backup overwrites the original file!
Sometimes I wondered if I made intermediate saves without realizing it...
Instead I realized that having the backup scheduled (5min.), This overwrites the original one, losing it inexorably!
Does this also apply to any of you or am I the only one who has automatic backup turned on and this happens?
For designers:
The periodic backup must be performed by creating a file (bak) of the type: filename.bak or even better: filename.bak1, filename.bak2...
With current software there is the error that if you are working and take a break, or realize the change is incorrect, exiting the project is a big mistake because the original project has been overwritten by the backup! losing it!
The only option is to do several "undo" to go back to the original or intermediate point before exiting, and this is not always possible!
Second:
By protecting the file in "read only", any operation on the file is blocked, even the "copy lock" useful for copying to other projects...
Instead it should be possible to work and ONLY at the time of saving there is the overwrite block.
A bit like it happens in the elements!
or am I wrong?
best regards.
