Topic: Coil-references
Hello @ all!
First I want to say, that I like to work with QElectroTech. It's a good solution for small projects and a very nice alternative for eplan.
Today I installed v0.9 after I used v0.8 for a very long time. Wow, it's a lot faster!
I realize some differences within the coil-references. I think the orientation has changed. You can see the differences on the attachment-picture. I don't know if it's a bug or not.
Is there a solution to change the position of the references? I like the older orientation (left side from picture) more than the newer one. The differences are present if there is a changer linked to the coil at the bottom of the list.
A few examples are on the pictures too.
Thanks for your help!
Re: Coil-references
Hello and thanks for compliments,
We added new other element and we change a lot xrefs draw for that, see:
https://github.com/qelectrotech/qelectr … r/pull/222
https://qelectrotech.org/forum/viewtopi … 475#p16475
Re: Coil-references
Thanks for your reply!
I checked the content from the links but it would help me, if it's possible to make a short summary for my case.
I'm not so familiar with the code, only user-level and basic programming skills. Sorry!
The solution with the references direct to the coil is also interesting, but I have no idea how this work.
Thanks for the help!
Re: Coil-references
https://qelectrotech.org/forum/viewtopi … 591#p16591
https://download.qelectrotech.org/qet/f … prove5.png
Re: Coil-references
Thanks a lot for the fast support. I try to make it this way.
