Topic: Title Block Text
Is there any way of creating a text box in the title block that is a variable which the user can select and change. For example if the revision changed due to additional switchgear how would the user update the description field. I was thinking of a _ similar to the elements place marker which when double clicked on the text would be editable.
Re: Title Block Text
https://download.qelectrotech.org/qet/m … ables.html
%{indexrev}: Folio revision index
https://qelectrotech.org/forum/viewtopi … 774#p17774
Thank you for the reply. I have managed to do that. I have attached the text boxes that I am referring to. Would I have to access the Custom field for each folio and change the custom text? Is there anyway of doing this directly from the title block and typing in the required text.
