Topic: Conductor Labels
Is there a way to get the same label at the start and end of the wire?
QElectroTech → FR : Aide, suggestions, discussions, ... → Conductor Labels
As far as I know, there is no way to add two labels on one conductor, you can manually write a label though..
No it's not possible, but added to the todo list
Sorry for my English, I used google translate.
Good morning,
Here is the trick I use to have 2 labels on 1 conductor.
I duplicate 1 of the elements (I put it in backward: important) and I superimpose it on the 1st.
Pay attention to the position of the element (Front or backward) because if you connect 1 new conductor (it always connects to the element most in front / to be confirmed), it may not be connected to the right element, and this will cause problems if you delete the duplicated element (folio reference/terminal blocks, etc.) as well as in the management of terminal blocks or others (2 elements to be managed instead of just 1): on the attached diagram I have separated the 2 elements at the bottom of the page to display the result.
(I have attached 1 project with explanations)
The advantage of my trick is that if the conductor label changes, I can apply it to all the labels linked together, whereas if I had put a text field, it must be modified manually.
There may be more simple, here is my trick.
Thanks, frskolon,
Great idea.
Good morning,
The advantage of my trick is that if the conductor label changes, I can apply it to all the labels linked together, whereas if I had put a text field, it must be modified manually.There may be more simple, here is my trick.
Thanks for sharing the tips mate
Generated in 0.034 seconds (14% PHP - 86% DB) with 12 queries
