Topic: DWG File
I have a DWG file I want to import into QElectroTech. Its a 2D electrical drawing for a Horner PLC. How would I do this?
QElectroTech → Import DXF → DWG File
DWG need to be converted to DXF ASCII format for work and can be converted after by QET converter plugins like DXFtoQET or Dxf2elmt see download page for informations:
https://qelectrotech.org/download.html.en
On the 0.9-dev Dxf2elmt can be easy installed: https://qelectrotech.org/forum/viewtopic.php?id=2265
Hi everyone, I am new at Qelectrotech and I would like to import dxf file in elemt configuration. It takes very long to import because my file is 4MB. Is there something I have missed or could someone help to solve this issue or give me a right direction to solve this problem?
you could share your DXF zip file here, for try?
You use DXFtoQET or Dxf2elmt?
Generated in 0.022 seconds (34% PHP - 66% DB) with 11 queries
