Topic: Suggestion: Folio Order in project tree
Hi Guys,
I have project with approx 100 folios.
Moving the folios up or down the project tree using F3, F4 or jump 10 works but is very slow.
Could the a mechanism be implemented to  drag and drop the folio to a new position.
(or I should be more accurate with planning)
(or perhaps there is a way that I am not aware of)
Example 1
if folio 50 was required in position 11 then the folio (50) is clicked & dragged up the project tree using the mouse and placed on folio 10.  The program re-positions the folio from 50 to 11.
Note the folio is placed one position greater than the position required.
Example 2
if folio 2 is required in position 1 then the folio (1) is clicked & dragged down the project tree using the mouse and placed on folio 2.   The program re-positions the folio from 1 to 2.
Hopefully, the above makes sense and is of use.
Other wise I have been learning the program during this project my first, and the program is very very good. Thank you to the developers.
Re: Suggestion: Folio Order in project tree
Hi Tray,
you can also move folio position by click & move with mouse on folio fields.
Left click in the folios tab and move its position with the mouse, beware it can go very quickly ...
3 (edited by abakus 2022-11-11 12:47:56)
For me it would be the most wanted feature to rearrange the folios per drag & drop.
According to scorpio it should already work but it does not work for me :-/
Here is how I tried it:
I added a new folio. The new folio is created at the last position (it's position 175 in my project).
Now I want to move that newly created folio to position 12. So I move the mouse pointer over the folio in the folios tab, click and hold the left mouse button and try to drag it up but it doesn't moves. So I need to push F3 more than 150 times to move the folio up.
What I am doing wrong?
Thank you so much for your help
https://download.qelectrotech.org/qet/forum_img_2/moving_folio.png
Thank you. I know that but moving per drag and drop would be more precise and faster.
I just wonder if the following is not working only for me or if the features was removed since your post:
"you can also move folio position by click & move with mouse on folio fields.
Left click in the folios tab and move its position with the mouse, beware it can go very quickly ... "
source: your post above
https://git.tuxfamily.org/qet/qet.git/c … 0f20c34aca
https://download.qelectrotech.org/qet/forum_img_2/moving_foliox100.png
7
Yes isn't working as expected, like in the past... Don't know why or it's my Debian unstable with recently libs  break it...
8
Okay, thank you. I'll try the posted modification
Edit: It works pretty well but only for small projects.. when you only want move folio by 5 at 10 steps maximum.. every time.
Packages is published, you can try it.
10
Works perfect, thank you!
