Topic: Suggestion: Folio Order in project tree
Hi Guys,
I have project with approx 100 folios.
Moving the folios up or down the project tree using F3, F4 or jump 10 works but is very slow.
Could the a mechanism be implemented to drag and drop the folio to a new position.
(or I should be more accurate with planning)
(or perhaps there is a way that I am not aware of)
Example 1
if folio 50 was required in position 11 then the folio (50) is clicked & dragged up the project tree using the mouse and placed on folio 10. The program re-positions the folio from 50 to 11.
Note the folio is placed one position greater than the position required.
Example 2
if folio 2 is required in position 1 then the folio (1) is clicked & dragged down the project tree using the mouse and placed on folio 2. The program re-positions the folio from 1 to 2.
Hopefully, the above makes sense and is of use.
Other wise I have been learning the program during this project my first, and the program is very very good. Thank you to the developers.
