Topic: Quality of the elements
Hello scorpio810!
I assume that you are responsible for maintaining the elements in QElectroTech.
I wanted to draw a small pneumatic plan, but found that the quality of the elements is very poor.
The housings are of different sizes, the connector pins are in different positions ...
Is there an interest in the elements being redrawn?
Tell me if you're interested and I'll do it when I find time.
The elements have the same name only have to be exchanged.
Wishing a nice evening!
Attachment icon Bildschirmfoto_2022-03-07_21-26-09.png 36.06 kb, 288 downloads since 2022-03-07
Re: Quality of the elements
Hello Vbxler,
you are welcome, and yes I am interested in redrawing, if of course you have time to improve these pneumatic symbols.
Hi Vbxler,
I 200% agree, only one thing make sure the position of the terminals (red stick with blue dot) are in a multiple of 10. The blue dot must be in a cross not in a dot of the grid.
4 (edited by Vbxler 2022-03-10 18:40:40)
Hello scorpio810,
1) is it a problem if I change the structure of the elements?
Now it's like this:
31_control_valves
     11_manual_actuation
     21_pneumatic_actuation
     31_electric_actuation
I would adjust the classification like this:
31_control_valves
   2/2_way  -> All valves of this type with the different actuations.
   3/2_way  -> All valves of this type with the different actuations.
   4/2_way  -> ...
2) Why is the tank cut off in the preview of the elements? (Foto_2022-03-09_21-59-34.png)
When I drag this tank onto the foil, it is shown as in the picture Foto_2022-03-09_22-01-24.png.
I am currently using:
QElectroTech V 0.90-DEV+bb1a0767a
Built with Qt 5.15.2 - Date : Feb 25 2022 : 13:48:09
Thank you for your help
Hello scorpio810,
could you please take a look and see if it meets your expectations.
Some wayvalves, cylinders, ... are still missing, but I will complete them all.
If I get a response I can continue the work.
Hi Vbxler,
very nice, for me you could continue, thanks.
@Joshua: l'option antialias n’apparaît plus dans le widget informations.
Hi Vbxler,
very good, it look more professional nomicons/smile, thanks.
@scorpio810 : ça fait un moment que l'option n'existe plus, l'antialiasing est toujours activé. J'ai d'ailleurs jamais trop compris pourquoi cette option existais, vu les pc actuel c'est pas ça les feraient souffrir.
@Joshua: Ça gène en rien mais les thumbnails affichés dans la collection de Vbxler sont flous.
Edit il semble que ça provienne de mon écran UHD.
https://download.qelectrotech.org/qet/scorpio/flou.png
<description>
        <dynamic_text z="1" text_from="ElementInfo" x="18" Valignment="AlignTop" y="-30.95" text_width="-1" uuid="{87cbda4d-ec99-430f-b572-7a2c506b987c}" rotation="0" font="Sans Serif,5,-1,5,50,0,0,0,0,0" frame="false" keep_visual_rotation="false" Halignment="AlignLeft">
            <text></text>
            <info_name>label</info_name>
        </dynamic_text>
        <arc x="2" width="30" y="-20" style="line-style:normal;line-weight:normal;filling:none;color:black" height="40" start="-135" antialias="true" angle="-90"/>
        <rect x="-10" width="20" y="-25" style="line-style:normal;line-weight:normal;filling:none;color:black" height="50" antialias="false" ry="0" rx="0"/>
        <polygon y3="-8" x2="6" y1="-6" x1="4" x3="8" style="line-style:normal;line-weight:thin;filling:black;color:black" x4="4" antialias="true" y2="-4" y4="-6"/>
        <line x2="5" y1="8" x1="-8" end1="none" style="line-style:normal;line-weight:normal;filling:none;color:black" end2="none" antialias="false" length1="1.5" length2="1.5" y2="-5"/>
        <line x2="0" y1="25" x1="0" end1="none" style="line-style:normal;line-weight:normal;filling:none;color:black" end2="none" antialias="false" length1="1.5" length2="1.5" y2="-25"/>
        <arc x="-32" width="30" y="-20" style="line-style:normal;line-weight:normal;filling:none;color:black" height="40" start="45" antialias="true" angle="-90"/>
        <terminal x="0" name="" y="-30" uuid="{b536d5e5-9b84-44a1-9a19-d378c287b008}" type="Generic" orientation="n"/>
        <terminal x="0" name="" y="30" uuid="{c220d9c9-c245-4ae4-966d-ccde0cbfa575}" type="Generic" orientation="s"/>
    </description>
</definition>
Hello, everyone,
I'll send you the reworked pneumatic symbols.
See if that's okay. Perhaps one or the other directional control valve is still missing. But I can add that.
The translations are all done with the new program qet_translate.
If you had to do it by hand, you would give up first.
Nice evening.
Hello Vbxler,
great work, added thanks.
I move old  50_pneumatic_/ element directory to https://github.com/qelectrotech/qelectr … nt-contrib
