Topic: BUG: Rotated Arcs in Element Editor
When I do an arc, rotate it and then save the element, the rotated arc is not saved in the right place.
Observe:
qet_element_pre_save.png, 14.4 kb, 760 x 1216
Re: BUG: Rotated Arcs in Element Editor
and post save
element_post_save.png, 12.27 kb, 735 x 1068
Workaround is to draw the two quarter arcs (why can't I draw an half-circle in the first place?) and not to copy and rotate a quarter arc.
Feels like paint 1994.
4 (edited by plc-user 2021-10-19 11:17:28)
Du hast gesehen, dass Du die Parameter für den Bogen editieren kannst?
Du brauchst da nichts rotieren!
english:
You noticed that you can edit the arc's parameters?
You don't have to rotate!
Bildschirmfoto_2021-10-19_11-10-06.png, 19.38 kb, 560 x 288
english:
Yeah sure. So everything where there is a workaround is not considered a bug?
@ q.e.d.
Why is the function provided for this purpose a workaround?
