Topic: BUG: Rotated Arcs in Element Editor
When I do an arc, rotate it and then save the element, the rotated arc is not saved in the right place.
Observe:
QElectroTech → EN : Help, suggestions, discussions, ... → BUG: Rotated Arcs in Element Editor
Observe:
and post save
Workaround is to draw the two quarter arcs (why can't I draw an half-circle in the first place?) and not to copy and rotate a quarter arc.
Feels like paint 1994.
Du hast gesehen, dass Du die Parameter für den Bogen editieren kannst?
Du brauchst da nichts rotieren!
english:
You noticed that you can edit the arc's parameters?
You don't have to rotate!
Du brauchst da nichts rotieren!english:
Yeah sure. So everything where there is a workaround is not considered a bug?
@ q.e.d.
Why is the function provided for this purpose a workaround?
Generated in 0.030 seconds (18% PHP - 82% DB) with 10 queries
