Re: Crash on loading project
Hmm, not fixed, strange FTBFS on Debian Buster:
sources/editor/ui/elementpropertieseditorwidget.cpp: In member function 'void ElementPropertiesEditorWidget::on_m_base_type_cb_currentIndexChanged(int)':
sources/editor/ui/elementpropertieseditorwidget.cpp:259:17: error: 'class QTabWidget' has no member named 'setTabVisible'; did you mean 'setVisible'?
ui->tabWidget->setTabVisible(1,
setVisible
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7168=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -isystem /usr/include/i386-linux-gnu/qt5 -isystem /usr/include/i386-linux-gnu/qt5/QtSvg -isystem /usr/include/i386-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/i386-linux-gnu/qt5/QtWidgets -isystem /usr/include/i386-linux-gnu/qt5/QtGui -isystem /usr/include/i386-linux-gnu/qt5/QtNetwork -isystem /usr/include/i386-linux-gnu/qt5/QtXml -isystem /usr/include/i386-linux-gnu/qt5/QtSql -isystem /usr/include/i386-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/i386-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/i386-linux-gnu/qt5/mkspecs/linux-g++ -o release/partline.o sources/editor/graphicspart/partline.cpp
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7168=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -isystem /usr/include/i386-linux-gnu/qt5 -isystem /usr/include/i386-linux-gnu/qt5/QtSvg -isystem /usr/include/i386-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/i386-linux-gnu/qt5/QtWidgets -isystem /usr/include/i386-linux-gnu/qt5/QtGui -isystem /usr/include/i386-linux-gnu/qt5/QtNetwork -isystem /usr/include/i386-linux-gnu/qt5/QtXml -isystem /usr/include/i386-linux-gnu/qt5/QtSql -isystem /usr/include/i386-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/i386-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/i386-linux-gnu/qt5/mkspecs/linux-g++ -o release/partpolygon.o sources/editor/graphicspart/partpolygon.cpp
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7168=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -isystem /usr/include/i386-linux-gnu/qt5 -isystem /usr/include/i386-linux-gnu/qt5/QtSvg -isystem /usr/include/i386-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/i386-linux-gnu/qt5/QtWidgets -isystem /usr/include/i386-linux-gnu/qt5/QtGui -isystem /usr/include/i386-linux-gnu/qt5/QtNetwork -isystem /usr/include/i386-linux-gnu/qt5/QtXml -isystem /usr/include/i386-linux-gnu/qt5/QtSql -isystem /usr/include/i386-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/i386-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/i386-linux-gnu/qt5/mkspecs/linux-g++ -o release/partrectangle.o sources/editor/graphicspart/partrectangle.cpp
g++ -c -pipe -std=c++17 -g -O2 -fdebug-prefix-map=/build/qelectrotech-0.90.r7168=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -std=gnu++11 -Wall -W -D_REENTRANT -fPIC -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQET_EXPORT_PROJECT_DB -DQAPPLICATION_CLASS=QApplication -DQT_MESSAGELOGCONTEXT -DQET_LANG_PATH=/usr/share/qelectrotech/lang/ -DQET_COMMON_COLLECTION_PATH=/usr/share/qelectrotech/elements/ -DQET_COMMON_TBT_PATH=/usr/share/qelectrotech/titleblocks/ -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_PRINTSUPPORT_LIB -DQT_WIDGETS_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_XML_LIB -DQT_SQL_LIB -DQT_CONCURRENT_LIB -DQT_CORE_LIB -I. -ISingleApplication -Isources/ui -isystem /usr/include/i386-linux-gnu/qt5 -isystem /usr/include/i386-linux-gnu/qt5/QtSvg -isystem /usr/include/i386-linux-gnu/qt5/QtPrintSupport -isystem /usr/include/KF5/KWidgetsAddons -isystem /usr/include/i386-linux-gnu/qt5/QtWidgets -isystem /usr/include/i386-linux-gnu/qt5/QtGui -isystem /usr/include/i386-linux-gnu/qt5/QtNetwork -isystem /usr/include/i386-linux-gnu/qt5/QtXml -isystem /usr/include/i386-linux-gnu/qt5/QtSql -isystem /usr/include/i386-linux-gnu/qt5/QtConcurrent -isystem /usr/include/KF5/KCoreAddons -isystem /usr/include/i386-linux-gnu/qt5/QtCore -Irelease -isystem /usr/include/libdrm -I. -I/usr/lib/i386-linux-gnu/qt5/mkspecs/linux-g++ -o release/partterminal.o sources/editor/graphicspart/partterminal.cpp
make[2]: *** [Makefile.Release:7318: release/elementpropertieseditorwidget.o] Error 1
make[2]: *** Waiting for unfinished jobs....
