1 (edited by vyt.sima 2021-03-03 17:12:57)
Topic: Crash on loading project
Good day, experiencing some crashes then loading a project, not sure how to collect good debug log, found only one in qet temp dir. Windows event log doesn't show anything useful.
Last page processed in qet before crash is "Table of content". It is probably crashing on next page.
Is it somehow possible to fix error in project file with text editor? Not sure what part causes the crash.
QElectroTech V 0.80c+87c957a06d79751d3
Compilation : GCC 9.3.0
Built with Qt 5.15.2 - Date : Feb 21 2021 : 10:30:58
Run with Qt 5.15.2 using 8 thread(s)
CPU : NAME INTEL(R) CORE(TM) I7-7820HQ CPU @ 2.90GHZ
RAM Total : 16263 MB
RAM Available : 3170 MB
GPU : VideoProcessor Intel(R) HD Graphics Family
GPU RAM : RAM Total : AdapterRAM 1073741824 B
OS : winnt - x86_64 - Version : Windows 10 Version 1909 - Kernel : 10.0.18363
*** Qt screens ***
( 1 : 2560 x 1440 )
Re: Crash on loading project
you could share your project?
3 (edited by vyt.sima 2021-03-03 18:17:50)
Yes, I have attached it.
I have added some new elements recently with "Internal number" value of "PLC:CPU:1512SP" etc. maybe this is causing the crash.
Fatal: ASSERT failure in QList<T>::at: "index out of range", file /usr/include/x86_64-linux-gnu/qt5/QtCore/qlist.h, line 571 (/usr/include/x86_64-linux-gnu/qt5/QtCore/qlist.h:571, )
Hmm qlist.h
inline void QList<T>::removeAt(int i)
#if !QT_DEPRECATED_SINCE(5, 15)
    Q_ASSERT_X(i >= 0 && i < p.size(), "QList<T>::removeAt", "index out of range");
#endif
    if (i < 0 || i >= p.size()) {
#if !defined(QT_NO_DEBUG)
        qWarning("QList::removeAt(): Index out of range.");
#endif
        return;
#if QT_DEPRECATED_SINCE(5, 14) && QT_VERSION < QT_VERSION_CHECK(6,0,0)
    QT_DEPRECATED_VERSION_X_5_14("Use QList<T>(set.begin(), set.end()) instead.")
    static QList<T> fromSet(const QSet<T> &set);
    QT_DEPRECATED_VERSION_X_5_14("Use QSet<T>(list.begin(), list.end()) instead.")
    QSet<T> toSet() const;
    QT_DEPRECATED_VERSION_X_5_14("Use QList<T>(list.begin(), list.end()) instead.")
    static inline QList<T> fromStdList(const std::list<T> &list)
    { return QList<T>(list.begin(), list.end()); }
    QT_DEPRECATED_VERSION_X_5_14("Use std::list<T>(list.begin(), list.end()) instead.")
    inline std::list<T> toStdList() const
    { return std::list<T>(begin(), end()); }
#endif
Maybe its pages? I do not have 111 page in project.
crash.png, 26.94 kb, 775 x 189
6 (edited by De-Backer 2021-03-03 20:31:11)
you have something there,
usually a "for loop" somewhere that is out of range
when loading sheet 4?
37 diagram (sheets)
I project there was title, 2 table of content pages, and 4'th page circuit, not sure how its possible to create a for loop designing? Maybe wire loop?
8 (edited by De-Backer 2021-03-03 20:37:48)
I will test it => ok
9 (edited by De-Backer 2021-03-03 20:43:48)
mod nr 4
now we know what, now how.
Thank you, saved me quite some hours of work. Might share what caused the problem?
11 (edited by De-Backer 2021-03-03 20:52:14)
That's the how.
I would also like to know.
there is a mistake in this somewhere
<conductors>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{29bd38da-19ce-423c-a76f-a4749b0a9eff}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{c821c20f-93b4-44bc-aac2-18b4c7574c3e}" bicolor="false" vertirotatetext="90" terminal2="{975add6f-4ba5-44af-a4c0-e1f1c2024601}" num="1Z230V" y="-20" element1="{a6cfb164-9d2f-4e3a-bd54-cfb6a267fe99}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <segment orientation="horizontal" length="0"/>
                <segment orientation="horizontal" length="60"/>
                <segment orientation="horizontal" length="77"/>
                <sequentialNumbers>
                    <unit></unit>
                    <unitFolio></unitFolio>
                    <ten></ten>
                    <tenFolio>11</tenFolio>
                    <hundred></hundred>
                    <hundredFolio></hundredFolio>
                </sequentialNumbers>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="419" conductor_color="" bicolor="false" vertirotatetext="270" terminal2="102" num="419" y="-110" element1="{c30a36ed-dcf0-4265-b7ad-c0b8efcb83bd}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers/>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#e8e800" dash-size="10" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" color="#00aa00" bicolor="true" vertirotatetext="91" terminal2="94" num="" y="0" element1="{503c2006-1870-4935-9615-b6b56afb447d}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{f75b8c8d-508b-4346-a6df-8cda82201d98}" usery="90" freezeLabel="false" bus="" tension_protocol="L3" vertical-alignment="AlignRight" displaytext="1" formula="" userx="830" conductor_color="" element2="{c8e5c7e6-55c2-431f-bcb5-5f9cb809c130}" bicolor="false" vertirotatetext="270" terminal2="{367dd739-791b-4d8f-9e49-4a70fd990b19}" num="L3" y="0" element1="{cd754a25-4232-459e-b850-6a1849123874}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="L2" vertical-alignment="AlignRight" displaytext="1" formula="L2" conductor_color="" element2="{168218b6-90c7-4f41-9a5f-be39820ecf47}" bicolor="false" vertirotatetext="270" terminal2="{f75b8c8d-508b-4346-a6df-8cda82201d98}" num="L2" y="0" element1="{d30cab82-64cd-40e3-9da4-aa0c3995826f}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="63" freezeLabel="false" bus="" tension_protocol="L1" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" bicolor="false" vertirotatetext="270" terminal2="64" num="L1" y="120" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="L1" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{148aca8b-c2ee-4ed8-b0ea-31c142b070f4}" bicolor="false" vertirotatetext="270" terminal2="{f75b8c8d-508b-4346-a6df-8cda82201d98}" num="L1" y="0" element1="{0edbdabc-7045-4580-8e14-e9e1687702b8}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="60" usery="610" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" userx="640" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="110" num="412" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>12</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="20" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{f75b8c8d-508b-4346-a6df-8cda82201d98}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{4d07d98c-f2d7-4edb-9084-c7d2a146eb00}" color="#0000ff" bicolor="false" vertirotatetext="270" terminal2="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" num="_" y="-180" element1="{f2467772-0603-45aa-9bc5-8ff5cb484df8}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="20" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" freezeLabel="false" bus="" tension_protocol="L3" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" bicolor="false" vertirotatetext="270" terminal2="30" num="L3" y="0" element1="{c8e5c7e6-55c2-431f-bcb5-5f9cb809c130}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor rotation="450" condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{eacfd29f-4682-41c2-9783-cedb80773f13}" usery="430" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="419" userx="1200" conductor_color="" bicolor="false" vertirotatetext="270" terminal2="65" num="419" y="-110" element1="{302aa5ff-8c55-4137-9402-bc32408c60df}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="163" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="0VDC" conductor_color="" element2="{e0fd9dc6-b14b-49d5-9ec3-221a2b66b511}" color="#0055ff" bicolor="false" vertirotatetext="90" terminal2="{975add6f-4ba5-44af-a4c0-e1f1c2024601}" num="0VDC" y="-210" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="50" freezeLabel="false" bus="" tension_protocol="L3" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" bicolor="false" vertirotatetext="270" terminal2="134" num="L3" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#e8e800" dash-size="10" function="" text_color="#000000" terminal1="117" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" color="#00aa00" bicolor="true" vertirotatetext="91" terminal2="98" num="" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#e8e800" dash-size="10" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{458d09c0-4219-4942-9323-a919d51ebe38}" color="#00aa00" bicolor="true" vertirotatetext="91" terminal2="{f75b8c8d-508b-4346-a6df-8cda82201d98}" num="" y="0" element1="{2c9a4483-bf90-473a-ae29-76fceb822375}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="20" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{f75b8c8d-508b-4346-a6df-8cda82201d98}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" color="#0000ff" bicolor="false" vertirotatetext="270" terminal2="103" num="_" y="-140" element1="{4d07d98c-f2d7-4edb-9084-c7d2a146eb00}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#e8e800" dash-size="10" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" color="#00aa00" bicolor="true" vertirotatetext="91" terminal2="175" num="" y="0" element1="{662f4b03-c529-44a5-9de9-ee2f3e54632b}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="L2" vertical-alignment="AlignRight" displaytext="1" formula="L2" conductor_color="" element2="{6cdca061-ebdb-40f1-b25b-8fb7e85d3348}" bicolor="false" vertirotatetext="270" terminal2="{eacfd29f-4682-41c2-9783-cedb80773f13}" num="L2" y="0" element1="{168218b6-90c7-4f41-9a5f-be39820ecf47}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="34" freezeLabel="false" bus="" tension_protocol="L3" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{cd754a25-4232-459e-b850-6a1849123874}" bicolor="false" vertirotatetext="270" terminal2="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" num="L3" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#e8e800" dash-size="10" function="" text_color="#000000" terminal1="90" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" color="#00aa00" bicolor="true" vertirotatetext="91" terminal2="94" num="" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="33" freezeLabel="false" bus="" tension_protocol="L2" vertical-alignment="AlignRight" displaytext="1" formula="L2" conductor_color="" element2="{d30cab82-64cd-40e3-9da4-aa0c3995826f}" bicolor="false" vertirotatetext="270" terminal2="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" num="L2" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{14982e99-c093-43af-b9fd-d51f9ab5b9fd}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" element2="{40746bbb-4984-4269-9849-3f3f724b9943}" bicolor="false" vertirotatetext="90" terminal2="{b8c7bddb-002f-4b7a-9e04-50bfc059bbd8}" num="406" y="0" element1="{de3c7e3c-f777-426a-9c69-7e7df06b189e}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>06</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" freezeLabel="false" bus="" tension_protocol="L2" vertical-alignment="AlignRight" displaytext="1" formula="L2" conductor_color="" bicolor="false" vertirotatetext="270" terminal2="45" num="L2" y="0" element1="{9d1dbe60-6908-45f7-aaa9-8a9a4d6decca}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" freezeLabel="false" bus="" tension_protocol="L2" vertical-alignment="AlignRight" displaytext="1" formula="L2" conductor_color="" bicolor="false" vertirotatetext="270" terminal2="39" num="L2" y="0" element1="{168218b6-90c7-4f41-9a5f-be39820ecf47}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="L3" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{23a36ecd-f0d5-4556-8cf3-be1275d4d979}" bicolor="false" vertirotatetext="270" terminal2="{eacfd29f-4682-41c2-9783-cedb80773f13}" num="L3" y="0" element1="{f9b12bd7-b63e-458e-a972-08fd5c51e827}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="37" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" element2="{de3c7e3c-f777-426a-9c69-7e7df06b189e}" bicolor="false" vertirotatetext="90" terminal2="{33f1eaac-37ff-4e44-adac-a3ee52bac889}" num="405" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>05</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="51" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="L1" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="71" num="L1" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="133" freezeLabel="false" bus="" tension_protocol="L3" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{23a36ecd-f0d5-4556-8cf3-be1275d4d979}" bicolor="false" vertirotatetext="270" terminal2="{e1ea331a-7456-47f0-b991-0a2299d3023c}" num="L3" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{ff1226a4-7934-4269-8090-2c2279eed822}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="1Z0VDC" conductor_color="" color="#0000ff" bicolor="false" vertirotatetext="90" terminal2="29" num="1Z0VDC" y="0" element1="{4c8fd9cf-14ed-40c1-8a32-958ad20d0039}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="62" usery="610" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" userx="680" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="112" num="414" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>14</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="61" usery="610" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" userx="660" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="111" num="413" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>13</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{f75b8c8d-508b-4346-a6df-8cda82201d98}" freezeLabel="false" bus="" tension_protocol="L1" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{2347ddc1-c592-4c38-bb3f-c46bad986c08}" bicolor="false" vertirotatetext="270" terminal2="{975add6f-4ba5-44af-a4c0-e1f1c2024601}" num="L1" y="0" element1="{0edbdabc-7045-4580-8e14-e9e1687702b8}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{f04dd0a9-bb5d-41e6-9f84-9fd88a6bb1fe}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" element2="{40746bbb-4984-4269-9849-3f3f724b9943}" bicolor="false" vertirotatetext="90" terminal2="{e21a6db5-29b5-43b0-88ea-effe6b6c3869}" num="407" y="0" element1="{de3c7e3c-f777-426a-9c69-7e7df06b189e}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>07</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="20" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" color="#0000ff" bicolor="false" vertirotatetext="270" terminal2="66" num="_" y="-140" element1="{f2467772-0603-45aa-9bc5-8ff5cb484df8}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="47" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="178" num="418" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>18</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="52" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="L2" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="79" num="L2" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{f75b8c8d-508b-4346-a6df-8cda82201d98}" freezeLabel="false" bus="" tension_protocol="L2" vertical-alignment="AlignRight" displaytext="1" formula="L2" conductor_color="" element2="{35544f77-88be-49b3-869d-e82d4e4a1dd1}" bicolor="false" vertirotatetext="270" terminal2="{975add6f-4ba5-44af-a4c0-e1f1c2024601}" num="L2" y="0" element1="{9d1dbe60-6908-45f7-aaa9-8a9a4d6decca}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="20" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" color="#0000ff" bicolor="false" vertirotatetext="270" terminal2="67" num="_" y="-140" element1="{f2467772-0603-45aa-9bc5-8ff5cb484df8}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" usery="530" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" userx="680" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="59" num="1Z230V" y="0" element1="{9de669d8-01ee-415a-9d88-2330885fb4bc}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="L2" vertical-alignment="AlignRight" displaytext="1" formula="L2" conductor_color="" element2="{d30cab82-64cd-40e3-9da4-aa0c3995826f}" bicolor="false" vertirotatetext="270" terminal2="{f75b8c8d-508b-4346-a6df-8cda82201d98}" num="L2" y="0" element1="{9d1dbe60-6908-45f7-aaa9-8a9a4d6decca}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="35" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" element2="{de3c7e3c-f777-426a-9c69-7e7df06b189e}" bicolor="false" vertirotatetext="90" terminal2="{b8c7bddb-002f-4b7a-9e04-50bfc059bbd8}" num="403" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>03</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#e8e800" dash-size="10" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{8c522b4e-331f-49ac-938e-643c768522d8}" color="#00aa00" bicolor="true" vertirotatetext="91" terminal2="{ff1226a4-7934-4269-8090-2c2279eed822}" num="" y="0" element1="{2c9a4483-bf90-473a-ae29-76fceb822375}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="180" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="24VDC" conductor_color="RED" color="#ff0000" bicolor="false" vertirotatetext="90" terminal2="81" num="24VDC" y="0" type="multi" cable="" conductor_section="1.5" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="32" freezeLabel="false" bus="" tension_protocol="L1" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{148aca8b-c2ee-4ed8-b0ea-31c142b070f4}" bicolor="false" vertirotatetext="270" terminal2="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" num="L1" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="36" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" element2="{de3c7e3c-f777-426a-9c69-7e7df06b189e}" bicolor="false" vertirotatetext="90" terminal2="{e21a6db5-29b5-43b0-88ea-effe6b6c3869}" num="404" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>04</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="31" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="419" conductor_color="" element2="{c30a36ed-dcf0-4265-b7ad-c0b8efcb83bd}" bicolor="false" vertirotatetext="270" terminal2="{f75b8c8d-508b-4346-a6df-8cda82201d98}" num="419" y="-50" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="43" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="56" num="402" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>02</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="41" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="54" num="400" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>00</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="L1" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{9ce7a784-ab8c-47a7-b866-818896626cd4}" bicolor="false" vertirotatetext="270" terminal2="{eacfd29f-4682-41c2-9783-cedb80773f13}" num="L1" y="0" element1="{abdb4809-276d-4511-93f3-a4aed41b3ab7}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="115" usery="730" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" userx="660" conductor_color="" color="#aa0000" bicolor="false" vertirotatetext="90" terminal2="26" num="415" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>15</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" freezeLabel="false" bus="" tension_protocol="L3" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" bicolor="false" vertirotatetext="270" terminal2="40" num="L3" y="0" element1="{f9b12bd7-b63e-458e-a972-08fd5c51e827}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{9b994e78-4ee7-4034-9a4b-3eaaa4339f94}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" element2="{40746bbb-4984-4269-9849-3f3f724b9943}" bicolor="false" vertirotatetext="90" terminal2="{33f1eaac-37ff-4e44-adac-a3ee52bac889}" num="408" y="0" element1="{de3c7e3c-f777-426a-9c69-7e7df06b189e}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>08</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="80" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="24VDC" conductor_color="RED" element2="{2fbc4c39-0ffa-45b0-bc73-440e4b97d41e}" color="#ff0000" bicolor="false" vertirotatetext="90" terminal2="{975add6f-4ba5-44af-a4c0-e1f1c2024601}" num="24VDC" y="-210" type="multi" cable="" conductor_section="1.5" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#e8e800" dash-size="10" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" color="#00aa00" bicolor="true" vertirotatetext="91" terminal2="113" num="" y="0" element1="{503c2006-1870-4935-9615-b6b56afb447d}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{29bd38da-19ce-423c-a76f-a4749b0a9eff}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="1Z24VDC" conductor_color="" element2="{575d1cd6-ec77-45fd-bc49-c175bc6024d4}" color="#aa0000" bicolor="false" vertirotatetext="90" terminal2="{975add6f-4ba5-44af-a4c0-e1f1c2024601}" num="1Z24VDC" y="0" element1="{ea855bd8-20d7-4ac6-83e7-7af764fc7c50}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{ff1226a4-7934-4269-8090-2c2279eed822}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="1Z24VDC" conductor_color="" color="#aa0000" bicolor="false" vertirotatetext="90" terminal2="28" num="1Z24VDC" y="0" element1="{ea855bd8-20d7-4ac6-83e7-7af764fc7c50}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="181" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="0VDC" conductor_color="" color="#0055ff" bicolor="false" vertirotatetext="90" terminal2="164" num="0VDC" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="63" freezeLabel="false" bus="" tension_protocol="L1" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{9ce7a784-ab8c-47a7-b866-818896626cd4}" bicolor="false" vertirotatetext="270" terminal2="{e1ea331a-7456-47f0-b991-0a2299d3023c}" num="L1" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{975add6f-4ba5-44af-a4c0-e1f1c2024601}" freezeLabel="false" bus="" tension_protocol="L3" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{c8e5c7e6-55c2-431f-bcb5-5f9cb809c130}" bicolor="false" vertirotatetext="270" terminal2="{f75b8c8d-508b-4346-a6df-8cda82201d98}" num="L3" y="0" element1="{beb2168f-e027-4c96-a7e6-dab22978f0ad}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="20" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{e1ea331a-7456-47f0-b991-0a2299d3023c}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="419" conductor_color="" element2="{c30a36ed-dcf0-4265-b7ad-c0b8efcb83bd}" bicolor="false" vertirotatetext="270" terminal2="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" num="419" y="10" element1="{302aa5ff-8c55-4137-9402-bc32408c60df}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="49" freezeLabel="false" bus="" tension_protocol="L2" vertical-alignment="AlignRight" displaytext="1" formula="L2" conductor_color="" bicolor="false" vertirotatetext="270" terminal2="136" num="L2" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="20" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" color="#0000ff" bicolor="false" vertirotatetext="270" terminal2="96" num="_" y="-180" element1="{4d07d98c-f2d7-4edb-9084-c7d2a146eb00}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="L3" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{f9b12bd7-b63e-458e-a972-08fd5c51e827}" bicolor="false" vertirotatetext="270" terminal2="{f75b8c8d-508b-4346-a6df-8cda82201d98}" num="L3" y="0" element1="{cd754a25-4232-459e-b850-6a1849123874}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="42" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="55" num="401" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>01</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" freezeLabel="false" bus="" tension_protocol="L1" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" bicolor="false" vertirotatetext="270" terminal2="38" num="L1" y="0" element1="{abdb4809-276d-4511-93f3-a4aed41b3ab7}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <segment orientation="vertical" length="9"/>
                <segment orientation="vertical" length="51"/>
                <segment orientation="vertical" length="61"/>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="L1" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{abdb4809-276d-4511-93f3-a4aed41b3ab7}" bicolor="false" vertirotatetext="270" terminal2="{f75b8c8d-508b-4346-a6df-8cda82201d98}" num="L1" y="0" element1="{148aca8b-c2ee-4ed8-b0ea-31c142b070f4}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="53" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="L3" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="95" num="L3" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{29bd38da-19ce-423c-a76f-a4749b0a9eff}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="1Z0VDC" conductor_color="" element2="{b154652f-8272-4ae3-babc-4f7f5c6ca0f4}" color="#0000ff" bicolor="false" vertirotatetext="90" terminal2="{975add6f-4ba5-44af-a4c0-e1f1c2024601}" num="1Z0VDC" y="0" element1="{4c8fd9cf-14ed-40c1-8a32-958ad20d0039}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#e8e800" dash-size="10" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" color="#00aa00" bicolor="true" vertirotatetext="91" terminal2="97" num="" y="0" element1="{458d09c0-4219-4942-9323-a919d51ebe38}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="116" usery="730" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" userx="680" conductor_color="" color="#0000ff" bicolor="false" vertirotatetext="90" terminal2="27" num="416" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>16</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="135" freezeLabel="false" bus="" tension_protocol="L2" vertical-alignment="AlignRight" displaytext="1" formula="L2" conductor_color="" element2="{6cdca061-ebdb-40f1-b25b-8fb7e85d3348}" bicolor="false" vertirotatetext="270" terminal2="{e1ea331a-7456-47f0-b991-0a2299d3023c}" num="L2" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="-120" color2="#e8e800" dash-size="10" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{503c2006-1870-4935-9615-b6b56afb447d}" color="#00aa00" bicolor="true" vertirotatetext="91" terminal2="{f75b8c8d-508b-4346-a6df-8cda82201d98}" num="" y="0" element1="{458d09c0-4219-4942-9323-a919d51ebe38}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="48" freezeLabel="false" bus="" tension_protocol="L1" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" bicolor="false" vertirotatetext="270" terminal2="64" num="L1" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" freezeLabel="false" bus="" tension_protocol="L1" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" bicolor="false" vertirotatetext="270" terminal2="44" num="L1" y="0" element1="{0edbdabc-7045-4580-8e14-e9e1687702b8}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="46" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="177" num="417" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <tenFolio>17</tenFolio>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#e8e800" dash-size="10" function="" text_color="#000000" terminal1="{f75b8c8d-508b-4346-a6df-8cda82201d98}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{662f4b03-c529-44a5-9de9-ee2f3e54632b}" color="#00aa00" bicolor="true" vertirotatetext="91" terminal2="{367dd739-791b-4d8f-9e49-4a70fd990b19}" num="" y="0" element1="{192efe84-fbfb-4c5f-a6b8-6d0d1e56a0a3}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="22" num="1Z230V" y="0" element1="{94efd7dc-9df8-4177-aedb-27850c67554b}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#e8e800" dash-size="10" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{2c9a4483-bf90-473a-ae29-76fceb822375}" color="#00aa00" bicolor="true" vertirotatetext="91" terminal2="{f75b8c8d-508b-4346-a6df-8cda82201d98}" num="" y="0" element1="{192efe84-fbfb-4c5f-a6b8-6d0d1e56a0a3}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="23" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" element2="{429e8b5a-f8f5-4ad4-9432-c09c50d295ec}" bicolor="false" vertirotatetext="90" terminal2="{ff1226a4-7934-4269-8090-2c2279eed822}" num="420" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <tenFolio>20</tenFolio>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{9de669d8-01ee-415a-9d88-2330885fb4bc}" bicolor="false" vertirotatetext="90" terminal2="{f75b8c8d-508b-4346-a6df-8cda82201d98}" num="1Z230V" y="0" element1="{94efd7dc-9df8-4177-aedb-27850c67554b}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <hundred></hundred>
            </conductor>
            <conductor rotation="90" condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" usery="510" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" userx="540" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="21" num="410" y="0" element1="{589be95b-c8e5-4e54-aa87-2b9cfe0ea5ad}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <tenFolio>10</tenFolio>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" usery="510" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" userx="520" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="57" num="409" y="0" element1="{30a1f333-3c6d-4a40-9b02-37d7e856c99e}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <tenFolio>09</tenFolio>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="25" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" element2="{e888d393-377d-43ab-83f7-4f13056b2ba0}" bicolor="false" vertirotatetext="90" terminal2="{ff1226a4-7934-4269-8090-2c2279eed822}" num="422" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <tenFolio>22</tenFolio>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{f75b8c8d-508b-4346-a6df-8cda82201d98}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" element2="{40746bbb-4984-4269-9849-3f3f724b9943}" bicolor="false" vertirotatetext="90" terminal2="{f04dd0a9-bb5d-41e6-9f84-9fd88a6bb1fe}" num="_" y="0" element1="{589be95b-c8e5-4e54-aa87-2b9cfe0ea5ad}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#e8e800" dash-size="10" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{55760643-6bdf-4fd1-ab63-2253f7ca71d1}" color="#00aa00" bicolor="true" vertirotatetext="91" terminal2="{ff1226a4-7934-4269-8090-2c2279eed822}" num="" y="0" element1="{192efe84-fbfb-4c5f-a6b8-6d0d1e56a0a3}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
            </conductor>
            <conductor rotation="90" condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" usery="510" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" userx="520" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="20" num="409" y="0" element1="{30a1f333-3c6d-4a40-9b02-37d7e856c99e}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{367dd739-791b-4d8f-9e49-4a70fd990b19}" usery="510" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" userx="540" conductor_color="" bicolor="false" vertirotatetext="90" terminal2="58" num="410" y="0" element1="{589be95b-c8e5-4e54-aa87-2b9cfe0ea5ad}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{f75b8c8d-508b-4346-a6df-8cda82201d98}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{40746bbb-4984-4269-9849-3f3f724b9943}" bicolor="false" vertirotatetext="90" terminal2="{9b994e78-4ee7-4034-9a4b-3eaaa4339f94}" num="1Z230V" y="0" element1="{94efd7dc-9df8-4177-aedb-27850c67554b}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="24" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" element2="{c1f8f365-2472-4445-8d46-0444cc23f668}" bicolor="false" vertirotatetext="90" terminal2="{ff1226a4-7934-4269-8090-2c2279eed822}" num="421" y="0" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
                    <tenFolio>21</tenFolio>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{1d3bb613-e8e2-4bcd-8515-ff9a0459b3c3}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="" conductor_color="" element2="{a6cfb164-9d2f-4e3a-bd54-cfb6a267fe99}" bicolor="false" vertirotatetext="90" terminal2="{ff1226a4-7934-4269-8090-2c2279eed822}" num="1Z230V" y="0" element1="{9de669d8-01ee-415a-9d88-2330885fb4bc}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <segment orientation="horizontal" length="9"/>
                <segment orientation="horizontal" length="161"/>
                <segment orientation="vertical" length="270"/>
                <segment orientation="horizontal" length="391"/>
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <hundred></hundred>
            </conductor>
            <conductor condsize="1" onetextperfolio="1" x="0" color2="#000000" dash-size="2" function="" text_color="#000000" terminal1="{14982e99-c093-43af-b9fd-d51f9ab5b9fd}" freezeLabel="false" bus="" tension_protocol="" vertical-alignment="AlignRight" displaytext="1" formula="%id%seqtf_1" conductor_color="" element2="{30a1f333-3c6d-4a40-9b02-37d7e856c99e}" bicolor="false" vertirotatetext="90" terminal2="{f75b8c8d-508b-4346-a6df-8cda82201d98}" num="409" y="0" element1="{40746bbb-4984-4269-9849-3f3f724b9943}" type="multi" cable="" conductor_section="" numsize="7" horizrotatetext="0" horizontal-alignment="AlignBottom">
                <sequentialNumbers>
            </conductor>
        </conductors>
I will keep the old file for further inspection. Will check in some spare time.
By the way, file is in onedrive dir. And I usually keep QET open and sleep pc for days before doing reboot.
Maybe sleep and autosave functionality kicked in while going to sleep.
Might be one drive doing its shenanigan's, wouldn't be the first time files reverted to previous version.
Why keep QET open, is very slow to launch on your OS?
For very large projects, every day I increment the name of the project with a new date, I save it locally and I also share it on one of the NAS (Network Attached Storage) of the service.
For very big projects all days I increment project name by date and save it.
i'm using git for that. nomicons/smile
I keep it all open, in it's own spot on screen, don't have to move everything each time. This is first time project crashed, will keep project in git repo from now on.
16 (edited by De-Backer 2021-03-03 21:22:06)
at
https://git.tuxfamily.org/qet/qet.git/t … .cpp#n1409
for (auto cond    : qAsConst(added_conductors)) added_items << cond;
testing
nop "The program has unexpectedly finished." nomicons/unsure
BTW, if you have some spare time to translate QET interface to Lithuanian, you 're welcome.
Is easy and if you know GIt is better.
maybe it will help you.
This is the conductor that causes the crash (line2511 to 2525 in the original project file)
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <hundred></hundred>
            </conductor>
@ Achim: good catch. ;-)
Will do, for now trying to create some custom elements, and cope on best design and functionality.
Still not sure about how some circuits should be drawn/implemented, but i'm getting somewhere while drawing them.
21 (edited by De-Backer 2021-03-03 22:24:46)
                <sequentialNumbers>
                    <unit></unit>
                    <ten></ten>
                    <hundred></hundred>
            </conductor>
del
==> ok
clang-Tidy and Clazy warn me about this
Screenshot_20210303_212210.png, 307.2 kb, 1021 x 750
If it helps. One end was a splice, other terminal.
img.png, 50.63 kb, 855 x 586
https://download.qelectrotech.org/qet/forum_img_2/4_inlet.png
https://download.qelectrotech.org/qet/forum_img_2/5_security_perimeter.png
24 (edited by Joshua 2021-03-03 22:53:17)
I will see your project this next day to find where is the bug.
Even if the .qet file is broken, QElectroTech should not crash.
Fixed in master.
I'm curious to know how the default was come in .qet file.
Probably a use case we never though.
