Topic: Impossible d'ouvrir le programme
Bonjour, J'ai vu dans ce forum certain utilisateur qui ont eu des problème sous mac également.
Toutefois ils ont parvenu à ouvrir votre précieux programme après avoir installer qt - mac - cocoa - opensource - 4.6.4 .
Je l'ai fait mais rien n'y change toujours le même problème !
Process:         qelectrotech [739]
Path:            /Users/USER/Downloads/qelectrotech-1.app/Contents/MacOS/qelectrotech
Identifier:      com.yourcompany.qelectrotech
Version:         ??? (???)
Code Type:       X86 (Native)
Parent Process:  launchd [117]
Date/Time:       2013-03-30 17:30:22.781 +0100
OS Version:      Mac OS X 10.7.5 (11G63)
Report Version:  9
Interval Since Last Report:          7424 sec
Crashes Since Last Report:           9
Per-App Crashes Since Last Report:   5
Anonymous UUID:                      CD3AEB2E-2EF8-47F3-A647-9189356BF3A3
Crashed Thread: 0
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
  Library not loaded: QtSvg.framework/Versions/4/QtSvg
  Referenced from: /Users/USER/Downloads/qelectrotech-1.app/Contents/MacOS/qelectrotech
  Reason: image not found
Binary Images:
    0x1000 -   0x23dfe3 +com.yourcompany.qelectrotech (??? - ???) <8C491CA7-175A-77FE-D60B-7DB42A1A6030> /Users/USER/Downloads/qelectrotech-1.app/Contents/MacOS/qelectrotech
0x8fe20000 - 0x8fe52aa7  dyld (195.6 - ???) <60FD3471-A1D7-342E-99A7-3EDECDAEC6EC> /usr/lib/dyld
Model: MacBookAir4,2, BootROM MBA41.0077.B0F, 2 processors, Intel Core i5, 1.7 GHz, 4 GB, SMC 1.73f66
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 384 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333235533642465238432D48392020
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333235533642465238432D48392020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xE9), Broadcom BCM43xx 1.0 (5.106.198.19.22)
Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM128C, 121,33 GB
USB Device: FaceTime Camera (Built-in), apple_vendor_id, 0x850a, 0xfa200000 / 3
USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfa100000 / 2
USB Device: BRCM20702 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 5
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821f, 0xfa113000 / 7
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x024d, 0xfa120000 / 4
USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfd100000 / 2
Probleme de compatibilité ? Comment le résoudre ?
J'aspire votre aide précieuse ^^, Merci d'avance .
