Topic: Impossible d'ouvrir le programme
Bonjour, J'ai vu dans ce forum certain utilisateur qui ont eu des problème sous mac également.
Toutefois ils ont parvenu à ouvrir votre précieux programme après avoir installer qt - mac - cocoa - opensource - 4.6.4 .
Je l'ai fait mais rien n'y change toujours le même problème !
Process:         qelectrotech [739]
Path:            /Users/USER/Downloads/qelectrotech-1.app/Contents/MacOS/qelectrotech
Identifier:      com.yourcompany.qelectrotech
Version:         ??? (???)
Code Type:       X86 (Native)
Parent Process:  launchd [117]
Date/Time:       2013-03-30 17:30:22.781 +0100
OS Version:      Mac OS X 10.7.5 (11G63)
Report Version:  9
Interval Since Last Report:          7424 sec
Crashes Since Last Report:           9
Per-App Crashes Since Last Report:   5
Anonymous UUID:                      CD3AEB2E-2EF8-47F3-A647-9189356BF3A3
Crashed Thread:  0
Exception Type:  EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
  Library not loaded: QtSvg.framework/Versions/4/QtSvg
  Referenced from: /Users/USER/Downloads/qelectrotech-1.app/Contents/MacOS/qelectrotech
  Reason: image not found
Binary Images:
    0x1000 -   0x23dfe3 +com.yourcompany.qelectrotech (??? - ???) <8C491CA7-175A-77FE-D60B-7DB42A1A6030> /Users/USER/Downloads/qelectrotech-1.app/Contents/MacOS/qelectrotech
0x8fe20000 - 0x8fe52aa7  dyld (195.6 - ???) <60FD3471-A1D7-342E-99A7-3EDECDAEC6EC> /usr/lib/dyld
Model: MacBookAir4,2, BootROM MBA41.0077.B0F, 2 processors, Intel Core i5, 1.7 GHz, 4 GB, SMC 1.73f66
Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 384 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333235533642465238432D48392020
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80AD, 0x484D54333235533642465238432D48392020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xE9), Broadcom BCM43xx 1.0 (5.106.198.19.22)
Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Serial ATA Device: APPLE SSD SM128C, 121,33 GB
USB Device: FaceTime Camera (Built-in), apple_vendor_id, 0x850a, 0xfa200000 / 3
USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfa100000 / 2
USB Device: BRCM20702 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 5
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821f, 0xfa113000 / 7
USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x024d, 0xfa120000 / 4
USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfd100000 / 2
Probleme de compatibilité ? Comment le résoudre ?
J'aspire votre aide précieuse ^^, Merci d'avance .
Re: Impossible d'ouvrir le programme
Bon visiblement tu a déjà fait des recherches, mais lie quand même ça ,  http://qelectrotech.org/forum/viewtopic … mp;login=1 .
De plus tu n'a pas indiquer qu'elle version tu utilise. Pour information la 0,3 (actuellement en développement) est beaucoup plus évoluer que la 0,22 si tu veux en savoir plus: http://qelectrotech.org/wiki/doc/macosx .
Justement c'est sur ce post que j'ai vu que je devais apparemment installé la version 4.6.4 de QT mais rien n'y fait, je vais creuser encore , la version O.3 est déjà disponible pour MacOS ?
Est-ce obligatoire de télécharger Xcode ? je l'ai fait mais je ne comprends pas l'utilité .
Pour avoir la version 0,3 il faudra la compilé, et tu aura besoin de Xcode pour compilé. Si tu le souhaite lit le lien de la doc qui indique comment procédé.
Pour ton problème initial, je ne sait trop quoi te dire, si ce n'est te renseigné de ton coté (google) en fonction des erreurs reporté. Si toute fois tu arrive à résoudre ton problème, un retour sera la bienvenue.
