Topic: Installed the plugin but Qet still asks for its installation
Hi I've followed the steps got a successful installation but when launching from the menu "Project" I get the same installation required notification. using the Dev 0.80.
QElectroTech → Terminal block generator → Installed the plugin but Qet still asks for its installation
what your OS, QET version and python version?
Hi Scorpio810,
I'm using Windows 10 Pro (OS build 19042.746) / QElectroTech V 0.80-rc+c592b7a7fc957a06d79751d3
Compilation : GCC 9.3.0 / Python 3.9
If you launch qet_tb_terminal plugin after launching industrial.qet in example, plugin appear?
I'm trying to use the Project -> "Launch the terminal block creation plugin" and I get the usual "Error launching get_tb_generator", if I find the plugin in the python folder and lunch the .exe that seems to be opening the "open file". what's the location for that .exe if I put it in its place it should work, just dunno where to put it.
For installer QET package :
Put it on your C:\Users\[username]\AppData\qet\
#if defined(Q_OS_WIN32) || defined(Q_OS_WIN64)
if (openedProjects().count()){
success = process->startDetached("qet_tb_generator", {(QETDiagramEditor::currentProjectView()->project()->filePath())});
else {
success = process->startDetached("qet_tb_generator", {("")});
success = process->startDetached(QDir::homePath() + "/Application Data/qet/qet_tb_generator.exe", {(QETDiagramEditor::currentProjectView()->project()->filePath())});
else {
success = process->startDetached(QDir::homePath() + "/Application Data/qet/qet_tb_generator.exe", {("")});
success = process->startDetached(QDir::homePath() + "/qet_tb_generator.exe", {(QETDiagramEditor::currentProjectView()->project()->filePath())});
else {
success = process->startDetached(QDir::homePath() + "/qet_tb_generator.exe", {("")});
#elif defined(Q_OS_MAC)
success = process->startDetached("/Library/Frameworks/Python.framework/Versions/3.8/bin/qet_tb_generator", {(QETDiagramEditor::currentProjectView()->project()->filePath())});
else {
success = process->startDetached("/Library/Frameworks/Python.framework/Versions/3.8/bin/qet_tb_generator", {("")});
success = process->startDetached(QDir::homePath() + "/.qet/qet_tb_generator.app", {(QETDiagramEditor::currentProjectView()->project()->filePath())});
else {
success = process->startDetached(QDir::homePath() + "/.qet/qet_tb_generator.app", {("")});
Generated in 0.036 seconds (17% PHP - 83% DB) with 12 queries
