1 (edited by amelie.track 2021-01-24 21:04:24)
Topic: Space between letters occurs when creating PDF
Hello everyone.
I'm new to QElectrotech.
And sorry for my english.
I was trying to experiment at first, but I saw that I almost drew a whole project. The program is really great, thank you to all who contributed.
I want to ask a question. When I extract the pages of the project as PDF, there are spaces between the letters of the text I wrote in "source of text" depending on the item.
For example, the text I wrote is like this;
"SOL ARKA KOLON ACİL STOP BUTONU "
but when I export it looks like this;
"SO L A RKA KO LO N A C İL S TO P BU TO N U"
The sentences I use here are in Turkish.
What would you suggest to overcome this problem?
Thank you.
Re: Space between letters occurs when creating PDF
have you tried with argument "Width = 0 instead of -1?
Sorry, I shared the wrong picture.  Since the font I use is Sans Serif, there is a space in between, and the problem disappears when I do Times New Roman.
Is there an easy way to make all fonts Times New Roman?
Maybe, go to settings-> configure QET->text field and change fonts, re open your project.
Thanks, I will let you know after trying.
I did as you said but it didn't work, is there any other solution?
Maybe yes with open your project .qet file with an good text editor and replace fonts.
Make a backup before.
8 (edited by amelie.track 2021-02-04 18:50:13)
Hello again.  As you said, using the text editor (Notepad ++) I changed the fonts greatly.  However, there is a space between the texts on Conductor again, I did not change this font.  How can I change these fonts.  I write "53CDR" but it shows as "53C DR".
