<definition width="130" hotspot_y="76" version="0.80" type="element" hotspot_x="65" height="170" link_type="master">
<uuid uuid="{3429b359-dffd-4205-b4f5-5122286dfabc}"/>
<names>
<name lang="nl">test_element_norm</name>
</names>
<kindInformations>
<kindInformation name="type" show="1">coil</kindInformation>
</kindInformations>
<elementInformations>
<elementInformation name="manufacturer_reference" show="1"></elementInformation>
<elementInformation name="description" show="1"></elementInformation>
<elementInformation name="supplier" show="1"></elementInformation>
<elementInformation name="machine_manufacturer_reference" show="1"></elementInformation>
<elementInformation name="comment" show="1"></elementInformation>
<elementInformation name="plant" show="1"></elementInformation>
<elementInformation name="quantity" show="1"></elementInformation>
<elementInformation name="unity" show="1"></elementInformation>
<elementInformation name="manufacturer" show="1"></elementInformation>
<elementInformation name="designation" show="1"></elementInformation>
<elementInformation name="label" show="1">etiket</elementInformation>
</elementInformations>
<informations>info auteur</informations>
<description>
<line antialias="false" x2="30" x1="-40" style="line-style:normal;line-weight:normal;filling:none;color:black" end2="none" y1="-40" y2="-40" end1="none" length2="1.5" length1="1.5"/>
<rect antialias="false" width="70" style="line-style:normal;line-weight:normal;filling:none;color:black" rx="0" y="-30" x="-40" height="30" ry="0"/>
<circle antialias="false" diameter="40" style="line-style:normal;line-weight:normal;filling:none;color:black" y="-10" x="-60"/>
<polygon y3="50" antialias="false" x2="60" x1="0" style="line-style:normal;line-weight:normal;filling:none;color:black" y6="10" x5="0" y5="10" y1="10" y2="10" y4="10" x3="60" x4="0" x6="0"/>
<polygon y3="60" antialias="false" x2="30" x1="-25" style="line-style:normal;line-weight:normal;filling:none;color:black" y1="50" y2="50" y4="60" closed="false" x3="60" x4="60"/>
<text color="#000000" rotation="0" y="85" x="-45" text="T" font="Sans Serif,9,-1,5,50,0,0,0,0,0"/>
<arc antialias="true" width="65" start="90" angle="90" style="line-style:normal;line-weight:normal;filling:none;color:black" y="75" x="-15" height="30"/>
<dynamic_text z="8" rotation="0" Valignment="AlignTop" text_from="ElementInfo" uuid="{655686e9-d968-4a16-91a1-80252e014460}" y="-80" frame="false" x="-20" Halignment="AlignLeft" font="Sans Serif,9,-1,5,0,0,0,0,0,0,normal" text_width="-1">
<text>etiket</text>
<info_name>label</info_name>
</dynamic_text>
<terminal uuid="{9ac8e678-fd84-4a77-b3bd-3d8e1dc426fe}" orientation="n" y="-70" name="term" x="-55"/>
</description>
</definition>
convertelement:
<?xml version="1.0" encoding="UTF-8"?>
<definition height="170" hotspot_x="65" hotspot_y="76" link_type="master" type="element" version="0.80" width="130">
<names>
</names>
<kindInformations>
</kindInformations>
<description>
<!--line-->
<line antialias="false" end1="none" end2="none" length1="1.5" length2="1.5" style="line-style:normal;line-weight:normal;filling:none;color:black" x1="-40" x2="30" y1="-40" y2="-40"/>
<!--rect-->
<rect antialias="false" height="30" style="line-style:normal;line-weight:normal;filling:none;color:black" width="70" x="-40" y="-30"/>
<!--circle-->
<circle antialias="false" diameter="40" style="line-style:normal;line-weight:normal;filling:none;color:black" x="-60" y="-10"/>
<!--ellipse-->
<!--polygon-->
<polygon antialias="false" closed="" style="line-style:normal;line-weight:normal;filling:none;color:black" x1="0" x2="60" x3="60" x4="0" x5="0" x6="0" y1="10" y2="10" y3="50" y4="10" y5="10" y6="10"/>
<polygon antialias="false" closed="false" style="line-style:normal;line-weight:normal;filling:none;color:black" x1="-25" x2="30" x3="60" x4="60" y1="50" y2="50" y3="60" y4="60"/>
<!--arc-->
<arc angle="90" antialias="true" height="30" start="90" style="line-style:normal;line-weight:normal;filling:none;color:black" width="65" x="-15" y="75"/>
<!--dynamic_text-->
<dynamic_text Halignment="AlignLeft" Valignment="AlignTop" font="Sans Serif,9,-1,5,0,0,0,0,0,0,normal" frame="false" info_name="label" rotation="0" text="etiket" text_from="ElementInfo" text_width="-1" uuid="{655686e9-d968-4a16-91a1-80252e014460}" x="-20" y="-80" z="8"/>
<!--terminal-->
<terminal nameHidden="" number="0" orientation="n" terminalname="term" x="-55" y="-70"/>
</description>
</definition>
ok it still contains errors, but i'm making progress.
