Re: connection list export
scorpio810 aren't you going too fast? we have not yet decided where to place the terminal name in the project file and what it looks like.
QElectroTech → EN : Help, suggestions, discussions, ... → connection list export
there is already a name in the terminal? It just needs to be filled....
For now no, but yes if you compile Simon branch :
https://github.com/De-Backer/qelectrote … minal_name
With the work of Martin we can determine the information of the terminals connected on the two points of a conductor (UUID element 1 and UUID terminal 1) first point of connection, (UUID element 2 and UUID terminal 2) second point of connection.
Like in this example :
Terminals informations need {element type=?}, {terminalblock=X11}, {label name=DIOO} and {pin number=1} Input/Output, Power, etc ... properties, it's time to think about it for the future ...
scorpio 810, joshua and martin did you get my email?
Joshua takes advantage of his vacation to do work on his house.
He doesn't turn on his PC much, from what he told me yesterday.
Thanks for informing me.
I will work on the debugger in the meantime.
There are still many things to do besides terminal name.
Just curiosity: Any progress on this in the past 15 months?
I am very interested in netlist extraction, so it can be verified by a script:
- Are all my switches, lamps, breakers ... connected
- Outputs of switches connected to right lamps
- Interesting with Loxone/KNX ... where it can be a bit more complicated.
Thank you
Generated in 0.022 seconds (30% PHP - 70% DB) with 11 queries
