Topic: connection list export
is it possible to export a list which contains the information which components are connected to each other?
Thanks!
Best regards
Dru
Re: connection list export
No, this list don't exist
3 (edited by DRU 2020-07-30 10:55:08)
Thanks for the reply!
but it should be possible to get it from the project file right?
Update:
I had a look into the project XML file.
It was easy to create a list which element is connected to each other, but there is a big problem. There is no option to give names to the connectors of a element. Or is it possible?
Currently I can generate a list where you see as example EL3214 is connect via 3 wires to a PT100. But you can't see which wire goes from the EL3214 to the connectors of the PT100
the terminals in the xml file has an attribute called name.
Is it possible to assign the name some where?
Thanks!
do you mean this?
(name)
it is being worked on but it is not yet possible.
Screenshot_20200730_164028.png, 21.73 kb, 1195 x 534
5 (edited by De-Backer 2020-07-30 20:22:51)
I think I got it working,
Joshua can this be tested?
https://github.com/De-Backer/qelectrote … minal_name
6 (edited by De-Backer 2020-07-30 18:17:13)
in test_element.elmt
<terminal x="0" uuid="{a9f1a07f-2a4a-460a-b6e7-d831f73e1a08}" name="21" orientation="s" y="30"/>
<terminal x="40" uuid="{93173c01-5706-498d-ab28-9fdb3dfe1a69}" name="23" orientation="s" y="30"/>
<terminal x="0" uuid="{1e57863e-e456-430b-a204-6831722b7312}" name="11" orientation="n" y="-30"/>
<terminal x="20" uuid="{42dd9184-b750-4ae3-8e89-593c958526f4}" name="12" orientation="n" y="-30"/>
<terminal x="20" uuid="{3dc51ac8-c354-499d-8c3b-f46ff6e435ad}" name="22" orientation="s" y="30"/>
<terminal x="40" uuid="{5455d1e1-4acb-47dd-8fcf-cb38fc88094a}" name="13" orientation="n" y="-30"/>
works
but in test.qet
diagram
<terminal x="0" id="0" nameHidden="0" orientation="0" name="_" number="_" y="-26"/>
<terminal x="20" id="1" nameHidden="0" orientation="0" name="_" number="_" y="-26"/>
<terminal x="40" id="2" nameHidden="0" orientation="0" name="_" number="_" y="-26"/>
<terminal x="0" id="3" nameHidden="0" orientation="2" name="_" number="_" y="26"/>
<terminal x="20" id="4" nameHidden="0" orientation="2" name="_" number="_" y="26"/>
<terminal x="40" id="5" nameHidden="0" orientation="2" name="_" number="_" y="26"/>
I search through it.
and the uuid? Why is not included?
Thank you
full file
Thank you
should that be?
Warning: I'm using google translator and word reference.
If I understood fine, DRU is asking about including the terminal names in the file .qet
With my poor experience using QElectroTech, I've perceived that the terminals and conductors look like the younger brothers of the elements. Terminals and conductors carry less information than elements, for instance name and uuid.
I think terminals and conductors should be at the same level of importance as the elements.
Why? I'm not too sure, but in my brain schematics they are all important.
Thank you.
PostScript: I always work with reference to objects by uuid.
Thank you.
You can be right, but we are going to break a lot if we mess around with that.
As it is now,my patch won't break anything but it will add the name in element.elmt
a night sleep does miracles.
I'm very interested in this issue. When I'll finish the transform editor, I'd like to explore the related code. And the data base. Big plans and little time.
Good night.
13
yes, terminal names in the .qet file would be great!
I think this feature brings a big benefit with it. With the list you can easily check for errors and miss wiring in cabinets.
I can provide the tool for the list generation. I'm not good in CPP but a little bit of knowledge in Python is provided.
Martin is working on this feature https://github.com/Murmele/qelectrotech-source-mirror
https://framaestro.org/p/#MTM1NDk1/qele … lang%3Den;
15 (edited by De-Backer 2020-07-31 21:26:22)
-The database should be editable by user, to let him add new data.
-Like elements, it will be great if users can send us there db to merge it with the official db of qelectrotech, then the official db will grow quickly and a lot of user will benefit.
Yes this would be a nice idea
eg KiCAD Library ?
https://kicad-pcb.org/libraries/download/
https://github.com/KiCad/kicad-symbols
but:
https://kicad-pcb.org/libraries/contribute/
an example:
https://youtu.be/Ae6nfh876gM
Is this where we want to go?
Sorry for answer you so late.
I didn't test your patch just read it, and see the screen-cast, everything look good nomicons/smile.
For me they miss one thing , add new kind of text : terminal text witch display the name of the terminal, the text should be static (not editable in the diagram editor), anyways it's good job nomicons/wink
Also see with Martin what he already made with terminal
https://invent.kde.org/marmsoler/qelect … rce-mirror
18 (edited by De-Backer 2020-08-02 18:35:34)
yes I understand what you mean, but this will be some "Dynamic text field / text field", because it will never be in the right place.
Martin Marmsoler authored 2 months ago
where is he, is he still working on it?
19 (edited by De-Backer 2020-08-05 22:30:42)
works
but in test.qet
diagram
terminal.cpp @ init("_", "_", false);
=>name="_" number="_"
Terminal::Terminal(TerminalData* data, Element* e) :
    QGraphicsObject(e),
    d(data),
    parent_element_(e)
    // TODO: what is when multiple parents exist. So the other relation is lost.
    d->setParent(this);
1 step further (name)
diagram
<terminals>
                    <terminal number="_" nameHidden="0" name="11" x="0" y="-26" orientation="0" id="0"/>
                    <terminal number="_" nameHidden="0" name="12" x="20" y="-26" orientation="0" id="1"/>
                    <terminal number="_" nameHidden="0" name="13" x="40" y="-26" orientation="0" id="2"/>
                    <terminal number="_" nameHidden="0" name="21" x="0" y="26" orientation="2" id="3"/>
                    <terminal number="_" nameHidden="0" name="22" x="20" y="26" orientation="2" id="4"/>
                    <terminal number="_" nameHidden="0" name="23" x="40" y="26" orientation="2" id="5"/>
                </terminals>
20 (edited by De-Backer 2020-08-05 22:52:14)
<conductor vertirotatetext="270" terminal1="{5455d1e1-4acb-47dd-8fcf-cb38fc88094a}" bicolor="true" element1="{01ef1122-8b93-40cd-bbb7-1e57eec47854}" dash-size="2" x="0" text_color="#000000" numsize="7" conductor_color="" horizontal-alignment="AlignBottom" displaytext="1" tension_protocol="" element2="{32ce3522-370f-42f3-99ae-dbb703d01767}" conductor_section="" vertical-alignment="AlignRight" freezeLabel="false" num="_" onetextperfolio="1" condsize="1" color2="#ff0000" function="" type="multi" horizrotatetext="0" terminal2="{93173c01-5706-498d-ab28-9fdb3dfe1a69}" formula="" y="0">
                <sequentialNumbers/>
            </conductor>
terminal1 in element collection:
<terminal name="13" x="40" y="-30" uuid="{5455d1e1-4acb-47dd-8fcf-cb38fc88094a}" orientation="n"/>
of element1 in diagram
<element prefix="" x="460" y="390" z="10" uuid="{01ef1122-8b93-40cd-bbb7-1e57eec47854}" freezeLabel="false" type="embed://import/test_element.elmt" orientation="0">
                <terminals>
                    <terminal number="_" nameHidden="0" name="11" x="0" y="-26" orientation="0" id="6"/>
                    <terminal number="_" nameHidden="0" name="12" x="20" y="-26" orientation="0" id="7"/>
                    <terminal number="_" nameHidden="0" name="13" x="40" y="-26" orientation="0" id="8"/>
                    <terminal number="_" nameHidden="0" name="21" x="0" y="26" orientation="2" id="9"/>
                    <terminal number="_" nameHidden="0" name="22" x="20" y="26" orientation="2" id="10"/>
                    <terminal number="_" nameHidden="0" name="23" x="40" y="26" orientation="2" id="11"/>
                </terminals>
                <inputs/>
                <dynamic_texts>
                    <dynamic_elmt_text text_width="-1" font="Sans Serif,9,-1,5,0,0,0,0,0,0,normal" rotation="0" Valignment="AlignTop" x="-25" y="-5" frame="false" text_from="UserText" uuid="{4828408a-9bca-4f1b-966f-089539358e21}" Halignment="AlignLeft">
                        <text>_</text>
                    </dynamic_elmt_text>
                </dynamic_texts>
                <texts_groups/>
            </element>
to element2 in diagram
<element prefix="" x="460" y="290" z="10" uuid="{32ce3522-370f-42f3-99ae-dbb703d01767}" freezeLabel="false" type="embed://import/test_element.elmt" orientation="0">
                <terminals>
                </terminals>
                <inputs/>
                <dynamic_texts>
                    <dynamic_elmt_text text_width="-1" font="Sans Serif,9,-1,5,0,0,0,0,0,0,normal" rotation="0" Valignment="AlignTop" x="-25" y="-5" frame="false" text_from="UserText" uuid="{24031ee2-36f3-4a95-80a9-eaf09479d2ef}" Halignment="AlignLeft">
                        <text>_</text>
                </dynamic_texts>
                <texts_groups/>
            </element>
terminal2 in element collection::
<terminal name="23" x="40" y="30" uuid="{93173c01-5706-498d-ab28-9fdb3dfe1a69}" orientation="s"/>
is unnecessary in diagram
the link is
element1 in diagram
element2 in diagram
conductor in diagram => makes the connection (uuid)
in short:
if the terminal have a name in element collection then we can make the list.
Or am I wrong?
21
Or am I wrong?
Yes.
As example:
If you have a Beckhoff IO module and you have pin names like IO1, IO2,... you can easily generate a list which gives you the information wich IO is connected to which element without reading the schematic.
It should then also be possible to generate netlists for creating PCB's.... I think this could also be another benefit.
Is there already a build available?
No, this is under development
This program is for drawing electrical diagrams and not for electronics
PCB = printed circuit boards
https://en.wikipedia.org/wiki/Printed_circuit_board
Let me explain the problem.
- Yes the code available can already provide the functionality. (branch dev_Terminal_name)
The problem:
Joshua wrote:
Martin work on a harness feature and if I remember well add terminal number.
They were all in the making of functionality, in a way I don't know yet.
If I now romel there, this will cause problems for the other features.
In short, if you make changes to the XML structure then all developers must know and agree to it.
And that's why it's still not in the master branch.
24 (edited by scorpio810 2024-07-06 10:25:33)
For making a list and find the name of the attached terminal1/terminal2 to conductor see
https://github.com/qelectrotech/qelectr … .cpp#L1126
Edit fix url
25 (edited by Re-searcher 2020-08-11 20:26:13)
Example :
                                             Magneto therminal circuit breaker
                                                    Element name = 10Q6
        uuid =
Power 3P-----conductor---*-terminal--terminal-----terminal------terminal--*----conductor
  Name---------name-------*-name-----uuid-----------uuid---------name---*------name
  L3----------conductor5---*-5 L3-----terminal5-----terminal6-----6 T3----*----conductor6---
  L2----------conductor3---*-3 L2-----terminal3-----terminal4-----4 T2----*----conductor4---
  L1----------conductor1---*-1 L1-----terminal1-----terminal2-----2 T1----*----conductor2---
