Topic: Terminals Out off componet body
Hi
When I put a component in the schematic, almost always, it has multiple terminals outside the body of the component. If I edit it, the exact same thing happens, although in the edition it doesn't.
Anotación 2020-07-06 165223.jpg, 19.88 kb, 491 x 438
Re: Terminals Out off componet body
What your version and OS, you use external monitor?
https://qelectrotech.org/forum/viewtopic.php?id=1372
https://qelectrotech.org/forum/viewtopic.php?id=1604
Ok. Thanks. It´s the monitor. When I place the window in a big monitor the terminals of component move itself. In the laptop´s monitor there isný trouble. Is there some way to solve or fix this problem?
Have you tried the latest 0.8? and I assume you are on Windows 10?
What spec monitor and laptop screen?
