Topic: Setting Sheet(Folio) Size
Maybe I don't correctly understand how Qelectrotech works. If that's the case, someone can correct me.
I'm working to create a schematic diagram and I have found that I don't have enough space on a single (default) sheet to fit one of my basic combinations (a PLC with selectable modules).
The default and other options for the sheets (folio) seems to be locked at A4 / Letter.
I would like to enlarge the sheet size to 'B' / Tabloid (11x17).
I can not seem to be able to find where I make this change, or how to create a user template that would support 11x17 sheet size.
Can someone out there give me some pointers? Or, direct me to an existing sheet library?
Thank you in advance for your time,
