Topic: ICP-DAS element
Hi, I am looking for element from the following image:
https://qelectrotech.org/gallery/photos … elasse.png (device on the right)
I can't find similar element in Collections or DXF file on the internet.
Thanks for help.
Re: ICP-DAS element
is only a picture not an element, no time to drawing this if I remember well.
Re: ICP-DAS element
I see. Thanks for quick answer.
If I am not wrong, it is not possible to add picture to the element itself - I dont see this option in the Element Editor.
Re: ICP-DAS element
Yes you can't add picture in element editor, the workaround is to add picture in diagram lock position and add terminal under picture for drawing conductors.
5 (edited by ArnoVal 2020-02-29 15:10:26)
Re: ICP-DAS element
Thanks for help.
Hello Mihicz,
Maybe these ICP-DAS elements can help you and maybe Scorpio will add them to the next QET version :-)
Arnaud
Re: ICP-DAS element
Ajoutés, merci Arnaud. nomicons/wink
https://git.tuxfamily.org/qet/qet.git/c … e1b7274afe
Re: ICP-DAS element
Zut, trop rapides tu es !
J'avais pas eu le temps de mettre mes infos perso dedans.
(j'ai fait la modif du tar sur le forum)
Re: ICP-DAS element
T’inquiètes pas, c'est fait.
Re: ICP-DAS element
10 (edited by S.DEFFAUX 2020-03-02 14:31:59)
Re: ICP-DAS element
Un oubli ? sur 2 éléments
11 (edited by ArnoVal 2020-03-02 14:59:37)
Re: ICP-DAS element
Le logo "ICP CON" ?
Il n'est pas dans la doc officielle (http://ftp.icpdas.com/pub/cd/8000cd/nap … l/7520.pdf).
Oubli ou pas ?
Oubli apparemment à la vue des photos des produits.
Re: ICP-DAS element
ArnoVal wrote:
Le logo "ICP CON" ?
Il n'est pas dans la doc officielle (http://ftp.icpdas.com/pub/cd/8000cd/nap … l/7520.pdf). Oubli ou pas ?
Peu être un oubli dans la doc officiel  lol
13 (edited by ArnoVal 2020-03-03 16:07:35)
Re: ICP-DAS element
Thanks for help.
Hello Mihicz,
Arnaud
Hello Mihicz,
A new file for 24 ICP-DAS elements :
i-7510A - RS-485/422 Repeater
i-7510AR - RS-422/485 Repeater
i-7510AR-G - RS-422/485 Repeater
i-7510 - RS-485 Repeater
i-7510P - RS-485 Repeater
i-7513 - RS-485 Hub
i-7513P - RS-485 Hub
i-7514U-G - 4CH Isolated RS-485 Hub
i-7520A - Isolated RS-232 to RS-422/485 Converter
i-7520AR - Isolated RS-232 to RS-422/485 Converter
i-7520AR-G - Isolated RS-232 to RS-422/485 Converter
i-7520 - Isolated RS-232 to RS-485 Converter
i-7520R - Isolated RS-232 to RS-485 Converter
i-7520R-G - Isolated RS-232 to RS-485 Converter
i-7520U4-CA-G - Isolated RS-232 to 4CH RS-485
i-7514U4-CA-G - Isolated RS-232 to 4CH RS-485
i-7551 - RS-232 to RS-232 Converter
i-7551-G - RS-232 to RS-232 Converter
i-7561 - USB to RS-232/422/485 Converter
i-7561-G - USB to RS-232/422/485 Converter
i-7561U-G - USB to RS-232/422/485 Converter
i-7563 - USB to 3 Ports RS-485 Hub Converter
i-7563-G - USB to 3 Ports RS-485 Hub Converter
i-7563U-G - USB to 3 Channels 485 Converter
Arnaud
Re: ICP-DAS element
6 ICP-DAS elements
ex-icp-das.png, 413.92 kb, 1500 x 1639
15 (edited by mihicz 2020-03-04 10:31:19)
Re: ICP-DAS element
Hi, thank you ArnoVal.
I use one of yours Element and modify it as ET-7042 (Ethernet I/O module) - attached.
Re: ICP-DAS element
Added, thanks mihicz.
Re: ICP-DAS element
Good job,
Are you interested by other elements from ICP-DAS ?
Re: ICP-DAS element
Thanks for your offer ArnoVal, but right now I happy with ET-7042.
Re: ICP-DAS element
Suite à un gros nettoyage des composants disponibles (considérés comme doublons) dans la version officielle du projet, Laurent a créé un projet Git (https://github.com/qelectrotech/qelectr … nt-contrib) contenant un grand nombre de ceux ci.
Pour les utiliser, vous devez d'abord les télécharger par le lien du projet qelectrotech-element-contrib : https://github.com/qelectrotech/qelectr … e/main.zip
English version:
Following a major cleaning of the available components (considered as duplicates) in the official version of the project, Laurent created a Git project (https://github.com/qelectrotech/qelectr … nt-contrib) containing a large number of these.
To use them, you must first download them from the project link qelectrotech-element-contrib: https://github.com/qelectrotech/qelectr … e/main.zip
Arnaud.
20 (edited by Rasec 2020-12-04 22:24:32)
Re: ICP-DAS element
and creating a list, editable to each user, within configurations, where the user would put the names of the manufacturers, power, equipment voltage, model etc. And when he uses the symbol, within the information, the configured list would inform the options, pattern and personnel of the elements ... less elements but many options.
