Topic: ICP-DAS element
Hi, I am looking for element from the following image:
https://qelectrotech.org/gallery/photos … elasse.png (device on the right)
I can't find similar element in Collections or DXF file on the internet.
Thanks for help.
QElectroTech → Elements → ICP-DAS element
Thanks for help.
is only a picture not an element, no time to drawing this if I remember well.
I see. Thanks for quick answer.
If I am not wrong, it is not possible to add picture to the element itself - I dont see this option in the Element Editor.
Yes you can't add picture in element editor, the workaround is to add picture in diagram lock position and add terminal under picture for drawing conductors.
Thanks for help.
Hello Mihicz,
Maybe these ICP-DAS elements can help you and maybe Scorpio will add them to the next QET version :-)
Arnaud
Ajoutés, merci Arnaud. ![]()
https://git.tuxfamily.org/qet/qet.git/c … e1b7274afe
Zut, trop rapides tu es !
J'avais pas eu le temps de mettre mes infos perso dedans.
(j'ai fait la modif du tar sur le forum)
T’inquiètes pas, c'est fait.
Un oubli ? sur 2 éléments
Le logo "ICP CON" ?
Il n'est pas dans la doc officielle (http://ftp.icpdas.com/pub/cd/8000cd/nap … l/7520.pdf).
Oubli ou pas ?
Oubli apparemment à la vue des photos des produits.
S.DEFFAUX wrote:Un oubli ? sur 2 éléments
Le logo "ICP CON" ?
Il n'est pas dans la doc officielle (http://ftp.icpdas.com/pub/cd/8000cd/nap … l/7520.pdf). Oubli ou pas ?
Peu être un oubli dans la doc officiel lol
mihicz wrote:Hi, I am looking for element from the following image:
Thanks for help.
Hello Mihicz,
Arnaud
Hello Mihicz,
A new file for 24 ICP-DAS elements :
i-7510A - RS-485/422 Repeater
i-7510AR - RS-422/485 Repeater
i-7510AR-G - RS-422/485 Repeater
i-7510 - RS-485 Repeater
i-7510P - RS-485 Repeater
i-7513 - RS-485 Hub
i-7513P - RS-485 Hub
i-7514U-G - 4CH Isolated RS-485 Hub
i-7520A - Isolated RS-232 to RS-422/485 Converter
i-7520AR - Isolated RS-232 to RS-422/485 Converter
i-7520AR-G - Isolated RS-232 to RS-422/485 Converter
i-7520 - Isolated RS-232 to RS-485 Converter
i-7520R - Isolated RS-232 to RS-485 Converter
i-7520R-G - Isolated RS-232 to RS-485 Converter
i-7520U4-CA-G - Isolated RS-232 to 4CH RS-485
i-7514U4-CA-G - Isolated RS-232 to 4CH RS-485
i-7551 - RS-232 to RS-232 Converter
i-7551-G - RS-232 to RS-232 Converter
i-7561 - USB to RS-232/422/485 Converter
i-7561-G - USB to RS-232/422/485 Converter
i-7561U-G - USB to RS-232/422/485 Converter
i-7563 - USB to 3 Ports RS-485 Hub Converter
i-7563-G - USB to 3 Ports RS-485 Hub Converter
i-7563U-G - USB to 3 Channels 485 Converter
Arnaud
6 ICP-DAS elements
Hi, thank you ArnoVal.
I use one of yours Element and modify it as ET-7042 (Ethernet I/O module) - attached.
Added, thanks mihicz.
Good job,
Are you interested by other elements from ICP-DAS ?
Thanks for your offer ArnoVal, but right now I happy with ET-7042.
Suite à un gros nettoyage des composants disponibles (considérés comme doublons) dans la version officielle du projet, Laurent a créé un projet Git (https://github.com/qelectrotech/qelectr … nt-contrib) contenant un grand nombre de ceux ci.
Pour les utiliser, vous devez d'abord les télécharger par le lien du projet qelectrotech-element-contrib : https://github.com/qelectrotech/qelectr … e/main.zip
English version:
Following a major cleaning of the available components (considered as duplicates) in the official version of the project, Laurent created a Git project (https://github.com/qelectrotech/qelectr … nt-contrib) containing a large number of these.
To use them, you must first download them from the project link qelectrotech-element-contrib: https://github.com/qelectrotech/qelectr … e/main.zip
Arnaud.
and creating a list, editable to each user, within configurations, where the user would put the names of the manufacturers, power, equipment voltage, model etc. And when he uses the symbol, within the information, the configured list would inform the options, pattern and personnel of the elements ... less elements but many options.
Generated in 0.023 seconds (28% PHP - 72% DB) with 11 queries
