1 (edited by McMarcopl 2019-09-22 13:06:44)
Topic: A few questions about QET
Hello
Everyone!
In the beginning I would like to thank you for the work you did to
createthe program.
I likethe program very much and it is intuitive.
I wouldlike to ask a few questions that I didn't find theanswer to in the forum. I'm using the following version of the program: QElectroTech V 0.80-DEV.
1. Isthere an option to automatically generate cables when drawing lines? I used the instructions on the forum and unfortunately it doesn't work. (like in this link download.qelectrotech.org/qet/joshua/Cable.webm with generate name of cable) Ican't run this function
2. CanI use Crossing addresses in the program to use  in the PLC I / O?
3. Howcan I make a valid list of materials?
Thankyouin advance for your help and answers
Re: A few questions about QET
Thanks for compliments.
1. is only a demo not added yet.
2. you can but with a lot of workaround, see in forums.
3. Project-> export csv. I you have added in all elements informations in the widget off course.
Cheers,
Cheers,
Thank's!
Could You tell me which version of QET is better? Version 0.70 orz 0.70 (DEV) ? Because i have a problem with polish language translate (it doesnt polish all words in program e.g. menu)
Best regards,
Jacek
Hello Jacek,
For me 0.80 DEV is better.
https://qelectrotech.org/wiki_new/doc/t … raductions
You can help Pawel, is easy to update translation example here :
Get the latest GIT sources here :
git clone git://git.tuxfamily.org/gitroot/qet/qet.git qet_git
or on Github mirror :
https://github.com/qelectrotech/qelectr … rce-mirror
For translating program interface you need to have qtlinguist application, it
installed by qtcreator program.
https://www1.qt.io/offline-installers/?hsLang=en
After just click on qet_pl.ts file in lang directory, it open qtlinguist.
http://doc.qt.io/qt-5/linguist-translators.html
Due comment chains in sources are in French you can open in the same editor
English translation, that can help you for translate.
When you work is finished click on save and publish and send me your qet_pl.ts
and qet_pl.qm file.
