Topic: feature set xref slave position
I have
i have now the problem that in dynamicelementtextitem.cpp
void DynamicElementTextItem::setPlainText(const QString &text)
    if (toPlainText() == text)
        return;
        else if (m_slave_Xref_item)
        QRectF r = boundingRect();
        QPointF pos(r.center().x() - m_slave_Xref_item->boundingRect().width()/2,
                    r.bottom());
        m_slave_Xref_item->setPos(pos);
I can not reference xrefProperties xrp = diagra...referencing
2 (edited by stromie 2019-07-20 14:10:43)
Re: feature set xref slave position
now the code, it is not ready
Ok I read the patch but don't try (I've got an issue to patch).
Everything look good, what exactly your problem ?
I try tomorrow to apply the patch and test it.
it is from 0.70rc2 tag
Yes off course is a patch based on old Subversion, please use
git clone git://git.tuxfamily.org/gitroot/qet/qet.git qet_git
Or fork https://github.com/qelectrotech/qelectr … rce-mirror
my problem is, the m_slave_Xref_item->SetPos will put in two function.
1. void DynamicElementTextItem::updateXref()
2. void DynamicElementTextItem::setPlainText(const QString &text)
in 1 i have
XRefProperties xrp = diagram()->project()->defaultXRefProperties(m_parent_element.data()->kindInformations()["type"].toString());
the Xrp variable has the info about the XrefPos
but in 2 there is not xrp
7
Why did you don't call it ?
write
in the method
and everything work very well.
May be it would be better to create a new method something like
DynamicElementTextItem::updateSlaveXrefPos
because the code for adjust the pos is bigger than before and take a lot of place in these two methods.
I try it, very good nomicons/wink
thanks Joshua
I had tried it on the weekend ever before with the insertion. But the program crashed. Today noticed that I have inserted it in the wrong place. Will finish it this week
9 (edited by stromie 2019-07-30 18:17:33)
I have a version ready. I hope that fits.
10
Ok, I haven't got time this week, but I will check your patch this weekend.
Thanks nomicons/smile
Hi Stromie,
great ! I tried your patch and it work well.
If you could keep source code  indentation tabs, like this edited patch. ;-)
12
Ok look good.
Just some little thing and after what, we can push your patch to qet nomicons/smile
1. Instead of use your own enum for left/right etc... you should use enum provide by Qt https://doc.qt.io/qt-5/qt.html#AlignmentFlag-enum I know there is not something for PosTextAignment but instead you can use AlignJustify or AlignBaseLine which in this case we are sure to not use it for a sixth alignment.
2. When use Qt enum we also can use QMetaEnum for a lot of thing and for us, get the name of the enum as a string to write it in the setting or the xml.
See dynamic element text item to/from xml to get an example.
3. When set pos to right, the Xref is far from the label
13 (edited by stromie 2019-08-04 16:39:49)
Thanks for testing
1. ok i use it
2. I have tried it but I have to look at me again in peace
3. i have fix it
https://github.com/stromie/qelectrotech-source-mirror
14
Hello Stromie,
you could sync your repository to QET mirror and make a Pull request, thanks.
15
Hello Scorpio810
Currently I am still trying to edit point 2 by Joshua. I'm not quite getting there yet.
16
Hello Stromie,
if you want some help, I can help you here or by mail.
Hi Joshua
i have fixe the point 2.
I am still new to Git. I tried to make a pull request
18
Hi Stromie,
sync your fork to mirror first, and create Pull request :
https://help.github.com/en/articles/cre … ll-request
19
Hi Stromie,
I can't add your Pull request your repository isn't up to date synced to master mirror and it remove some works.
wget https://github.com/qelectrotech/qelectr … l/11.patch
20
Hello Stromie, thanks added your work.
If user choose textitem alignment the change isn't on the fly, need to reload project to take change, you can fix it?
21
Hello
I have to see how I can trigger an update when changing. I will fix it.
22
please use this tabs policy for indentations. ;-)
https://download.qelectrotech.org/qet/forum_img/qtcreator_tabs_config.png
23
Hi Stromie,
if user set in project config Xrefs "text alignment" for manual editing text position by item, all Xrefs is moved to Top, please add Bottom by default.
24
Thanks to your contribution nomicons/smile
Ok, found !, In the general configuration of QET, the Xref_slave for all projects was badly defined on Top and override the one defined in the project configuration if I choose text alignment. It's my fault and I could have searched long time in the code, sorry for the noise. nomicons/blush
