1 (edited by stromie 2019-07-06 08:37:36)
Topic: Abstand Zwischen Betriebskennzeichnung und Querverlinkung
Hallo
könnte man den Abstand beim Slave zwischen der Betriebskennzeichung und der Querverlinkung
unter den Projektsettings einstellbar machen. Aktuell ist der Abstand für mich zu Groß.
Eventuell könnte mir einer der Programmier sagen, in welcher Datei der Abstand fest codiert ist. Dann könnte ich diesen selber anpassen.
Vielen dank für das gute Programm
Qelectro.PNG, 2.13 kb, 187 x 175
Re: Abstand Zwischen Betriebskennzeichnung und Querverlinkung
  Hallo,
I did not look, but from memory I think it must be in sources/qetgraphicsitem/crossrefitem.cpp
3 (edited by stromie 2019-07-07 20:01:13)
thanks, i will look
Look in dynamicelementtextitem.cpp ~ L 1353 m_slave_Xref_item boundingRect
Do you have skills in C ++ programming?
6 (edited by stromie 2019-07-10 19:52:30)
Hi scorpioB10
thanks for the info.
[left]My programming skills are limited to the hobby. Some years ago I programmed with C # and C ++. I can read and understand your code.
Currently I try the 0.70rc2 to builden. That under Windows.
[/left]
[left]If that's the case, I'll take a look at the change in distance.[/left]
[left]stromie
[/left]
7 (edited by stromie 2019-07-14 16:31:54)
it works, with the textalignment i can switch the xlink position.
bottom.PNG, 4.76 kb, 289 x 335
center.PNG, 4.7 kb, 343 x 279
Great ! You could send patch?
10 (edited by stromie 2019-07-14 19:27:36)
[left]here's a patch, but I think the better way is to use a configuration item.[/left]
Nice, thanks Stromie. ;-)
You're right, look in sources/ui/configpage/generalconfigurationpage.cpp.
https://git.tuxfamily.org/qet/qet.git/l … onpage.cpp
13 (edited by stromie 2019-07-15 16:31:14)
i think it is better to the text properties.
new item xlink_position
text.PNG, 7.01 kb, 363 x 328
Hello Stromie,
we thinking is better in project cross-reference settings, Joshua want to guide you.
https://download.qelectrotech.org/qet/forum_img/stromie_patch.png
ok, then we do this
16 (edited by stromie 2019-07-19 19:58:02)
look like this
Menu.PNG, 8.14 kb, 792 x 161
i have now the problem that in dynamicelementtextitem.cpp
void DynamicElementTextItem::setPlainText(const QString &text)
    if (toPlainText() == text)
        return;
        else if (m_slave_Xref_item)
        QRectF r = boundingRect();
        QPointF pos(r.center().x() - m_slave_Xref_item->boundingRect().width()/2,
                    r.bottom());
        m_slave_Xref_item->setPos(pos);
I can not reference xrefProperties xrp = diagra...referencing
Helo stromie good job nomicons/wink
Can you open a new topic on the section 'code' of the forum, and at least copy your last two post of this thread.
I will be happy to guide you for this feature.
