Topic: export numeric conductor
hi, i have a question. i make a new project and I numbered the Components. Now i want expot numbered conductor of my project but
I do not know how to do.
I have to manually copy the number of the conductor? It is a very long process with great loss of time. there is no way to read the project and export the conductor numbers?
thank's
Re: export numeric conductor
you want export all conductors name to a list, or add your conductors, element autonum rules to new project?
hi, i wont export conductor name into list if possible. i need a list of name of conductor.
@ karlAttrezzi
at the moment, it's not possible to export a wiring list (with conductor numbers, section, length and color) directly from QET.
But... Obvisouly, someone has already managed to do something similar using XSLT filters:
https://qelectrotech.org/forum/viewtopic.php?id=938
Sorry the topic is in french, use google translate.
Unfortunately, the user has not shared further information on how he achieved to do this.
ok, thanks
Nuri wrote:
@ karlAttrezzi
Yes, you can, but you need to use XMLStarlet  for extract a list <conductors> key and num="" value.
List of conductor properties :
  • condsize                -> conductor size
  • function
  • tension-protocol
  • formula
  • type                       -> multi/single
  • color                      -> example #ff0000
  • num                      -> conductor name
example :
 <conductor condsize="1" terminal2="15" function="test" numsize="7" horizrotatetext="0" x="0" y="0" num="1" onetextperfolio="1" displaytext="1" formula="" type="multi" tension-protocol="380v" vertirotatetext="270" terminal1="12" freezeLabel="false">
                <sequentialNumbers/>
            </conductor>
<conductor condsize="1.8" terminal2="11" function="" numsize="7" horizrotatetext="0" x="0" y="0" num="2" onetextperfolio="1" displaytext="1" formula="" type="multi" color="#ff0000" tension-protocol="" vertirotatetext="270" terminal1="8" freezeLabel="false">
XMLStarlet in QET examples :
https://qelectrotech.org/forum/viewtopi … 3777#p3777
https://qelectrotech.org/forum/viewtopi … 4579#p4579
Or use grep, sed awk xml_grep, etc
https://download.qelectrotech.org/qet/forum_img/conductor_num.png
laurent@debian:~/Desktop$ grep -oP 'conductor num="\K[^"]*' 3.qet
conduc text=1
conduc text=2
conduc text=3
conduc text=4
https://download.qelectrotech.org/qet/forum_img/conductor_num1.png
https://download.qelectrotech.org/qet/forum_img/conductor_num3.png
Other example : i want to extract in my project "parc_bois25.qet" all conductors name and export into a spreadsheet.
https://download.qelectrotech.org/qet/forum_img/conductor_num4.png
https://download.qelectrotech.org/qet/forum_img/conductor_num5.png
sed -n -e '/conductor/,/num/p' 3.qet | grep -oP 'num="\K[^"]*'
30
20
10 (edited by scorpio810 2016-12-22 19:00:54)
Based on Galexis script :
<conductors>
            <conductor x="0" type="multi" formula="555222" freezeLabel="false" numsize="7" horizrotatetext="0" function="L1" onetextperfolio="1" y="0" terminal1="14" vertirotatetext="270" terminal2="13" num="555222" displaytext="1" condsize="3" color="#00ffff" tension-protocol="220V">
            </conductor>
            <conductor x="0" type="multi" formula="" freezeLabel="false" numsize="7" horizrotatetext="0" function="TER" onetextperfolio="1" y="0" terminal1="0" vertirotatetext="270" terminal2="3" num="hhhh" displaytext="1" condsize="1" tension-protocol="48V">
            </conductor>
            <conductor x="0" type="multi" formula="" freezeLabel="false" numsize="7" horizrotatetext="0" function="L3" onetextperfolio="1" y="0" terminal1="4" vertirotatetext="270" terminal2="7" num="test" displaytext="1" condsize="1" tension-protocol="110V">
            </conductor>
            <conductor x="0" type="multi" formula="" freezeLabel="false" numsize="7" horizrotatetext="0" function="L2" onetextperfolio="1" y="0" terminal1="8" vertirotatetext="270" terminal2="11" num="25" displaytext="1" condsize="2" color="#0055ff" tension-protocol="380V">
            </conductor>
        </conductors>
laurent@debian:~/Desktop$ xmlstarlet sel -T -t -m /project/diagram/conductors/conductor -s A:N:- "@num" -v "concat(@num,';',@condsize,';',@function,';',@tension-protocol,';',@type,';',@color,';')" -n 4.qet
hhhh;1;TER;48V;multi;;
test;1;L3;110V;multi;;
25;2;L2;380V;multi;#0055ff;
555222;3;L1;220V;multi;#00ffff;
https://download.qelectrotech.org/qet/forum_img/conductor_num6.png
https://download.qelectrotech.org/qet/forum_img/conductor_num7.png
Attachment icon extract_conductors.csv 158 b, 564 downloads since 2016-12-22
Order by folio :
xmlstarlet sel -T -t -m /project/diagram/conductors/conductor -s A:N:- "@diagram" -v "concat(@num,';',@condsize,';',@function,';',@tension-protocol,';',@type,';',@color,';')" -n 4.qet
