Topic: Missing element
I did not notice with what version of the update is displayed, but the project were created elements propodaet me. And not every project. Some projects have disappeared, others remained. And no matter how much the old project. Unfortunately I did not make the user library. And in vain! Now I do. Unfortunately it is impossible to remove from the draft the missing elements in the draft elements of the menu. But interestingly, if the "element" of the scheme selected for editing, then everything is fine. You can even try to save, but in the project, he still does not appear.
Re: Missing element
My system - Ubuntu 14.4, Qelectrotech 0.51
3 (edited by Nuri 2016-04-01 11:51:45)
Re: Missing element
Hi Aleksandr,
Could you post some screenshots describing more accurately your problem?
Please could you post your message the next time in the english section, here:
http://qelectrotech.org/forum/viewforum.php?id=13
EDIT: your message is now moved in the right section.
Re: Missing element
Hi Aleksandr,
i think we have a little bug on latest devel packages.
If i open oldest project i see a few elements are lost.
[11:47:11] laurent@debian:~$ qelectrotech
QETSingleApplication::sendMessage() : QLocalSocket::connectToServer : Connexion refusée ( qelectrotech-UNKNOWN )
transaction began for  "common"
transaction commited for  "common"
transaction began for  "custom"
transaction commited for  "custom"
Diagram::fromXml() : Le chargement du conducteur 19 49 a echoue
Diagram::fromXml() : Le chargement du conducteur 18 49 a echoue
Diagram::fromXml() : Le chargement du conducteur 31 72 a echoue
Diagram::fromXml() : Le chargement du conducteur 30 72 a echoue
Diagram::fromXml() : Le chargement du conducteur 42 52 a echoue
Diagram::fromXml() : Le chargement du conducteur 51 45 a echoue
Diagram::fromXml() : Le chargement du conducteur 50 45 a echoue
Diagram::fromXml() : Le chargement du conducteur 52 45 a echoue
Diagram::fromXml() : Le chargement du conducteur 50 47 a echoue
Diagram::fromXml() : Le chargement du conducteur 73 77 a echoue
Diagram::fromXml() : Le chargement du conducteur 75 80 a echoue
Diagram::fromXml() : Le chargement du conducteur 74 80 a echoue
Diagram::fromXml() : Le chargement du conducteur 73 80 a echoue
Diagram::fromXml() : Le chargement du conducteur 61 58 a echoue
Diagram::fromXml() : Le chargement du conducteur 62 1 a echoue
Diagram::fromXml() : Le chargement du conducteur 61 1 a echoue
Diagram::fromXml() : Le chargement du conducteur 63 1 a echoue
Diagram::fromXml() : Le chargement du conducteur 12 37 a echoue
Diagram::fromXml() : Le chargement du conducteur 10 37 a echoue
Diagram::fromXml() : Le chargement du conducteur 11 37 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 9 a echoue
Diagram::fromXml() : Le chargement du conducteur 10 14 a echoue
Diagram::fromXml() : Le chargement du conducteur 1 9 a echoue
Diagram::fromXml() : Le chargement de la description de l'element embed://19_bornes2.elmt a echoue avec le code d'erreur 1
Diagram::fromXml() : Utilisation d'un GhostElement en lieu et place de cet element.
Diagram::fromXml() : Le chargement de la description de l'element embed://cle4.elmt a echoue avec le code d'erreur 1
Diagram::fromXml() : Le chargement de la description de l'element embed://cle2.elmt a echoue avec le code d'erreur 1
Diagram::fromXml() : Le chargement de la description de l'element embed://cellule2.elmt a echoue avec le code d'erreur 1
Diagram::fromXml() : Le chargement de la description de l'element embed://voyant5.5.elmt a echoue avec le code d'erreur 1
Diagram::fromXml() : Le chargement du conducteur 3 0 a echoue
Diagram::fromXml() : Le chargement du conducteur 7 1 a echoue
Diagram::fromXml() : Le chargement du conducteur 7 8 a echoue
Diagram::fromXml() : Le chargement du conducteur 3 9 a echoue
Comment item: can't found text tagged 'label' from actual parent element to set has parent, comment will be displayed at bottom of diagram
ElementsCollectionCache::fetchData() : Le chargement du composant project0+embed://19_bornes2.elmt a echoue avec le code d'erreur 1
ElementsCollectionCache::fetchData() : Le chargement du composant project0+embed://cellule2.elmt a echoue avec le code d'erreur 1
ElementsCollectionCache::fetchData() : Le chargement du composant project0+embed://cle2.elmt a echoue avec le code d'erreur 1
ElementsCollectionCache::fetchData() : Le chargement du composant project0+embed://cle4.elmt a echoue avec le code d'erreur 1
ElementsCollectionCache::fetchData() : Le chargement du composant project0+embed://voyant5.5.elmt a echoue avec le code d'erreur 1
Diagram::fromXml() : Le chargement des parametres d'un element a echoue
Diagram::fromXml() : Le chargement du conducteur 9 24 a echoue
Diagram::fromXml() : Le chargement du conducteur 11 25 a echoue
Diagram::fromXml() : Le chargement du conducteur 37 23 a echoue
Diagram::fromXml() : Le chargement du conducteur 33 39 a echoue
Diagram::fromXml() : Le chargement du conducteur 38 32 a echoue
Diagram::fromXml() : Le chargement du conducteur 28 17 a echoue
Diagram::fromXml() : Le chargement du conducteur 40 31 a echoue
Diagram::fromXml() : Le chargement du conducteur 29 28 a echoue
Diagram::fromXml() : Le chargement du conducteur 22 12 a echoue
Diagram::fromXml() : Le chargement du conducteur 36 27 a echoue
Diagram::fromXml() : Le chargement du conducteur 42 29 a echoue
Diagram::fromXml() : Le chargement du conducteur 6 11 a echoue
Diagram::fromXml() : Le chargement du conducteur 6 10 a echoue
Diagram::fromXml() : Le chargement du conducteur 6 9 a echoue
Diagram::fromXml() : Le chargement du conducteur 6 8 a echoue
Diagram::fromXml() : Le chargement du conducteur 4 15 a echoue
Diagram::fromXml() : Le chargement du conducteur 4 14 a echoue
Diagram::fromXml() : Le chargement du conducteur 4 13 a echoue
Diagram::fromXml() : Le chargement du conducteur 4 12 a echoue
Diagram::fromXml() : Le chargement du conducteur 7 19 a echoue
Diagram::fromXml() : Le chargement du conducteur 7 18 a echoue
Diagram::fromXml() : Le chargement du conducteur 7 17 a echoue
Diagram::fromXml() : Le chargement du conducteur 7 16 a echoue
Diagram::fromXml() : Le chargement du conducteur 5 23 a echoue
Diagram::fromXml() : Le chargement du conducteur 5 22 a echoue
Diagram::fromXml() : Le chargement du conducteur 5 21 a echoue
Diagram::fromXml() : Le chargement du conducteur 5 20 a echoue
Diagram::fromXml() : Le chargement du conducteur 1 0 a echoue
Diagram::fromXml() : Le chargement du conducteur 4 8 a echoue
Diagram::fromXml() : Le chargement du conducteur 5 24 a echoue
Diagram::fromXml() : Le chargement du conducteur 1 34 a echoue
Diagram::fromXml() : Le chargement du conducteur 2 15 a echoue
Diagram::fromXml() : Le chargement du conducteur 4 3 a echoue
Diagram::fromXml() : Le chargement du conducteur 1 33 a echoue
Diagram::fromXml() : Le chargement du conducteur 2 20 a echoue
Diagram::fromXml() : Le chargement du conducteur 1 26 a echoue
Diagram::fromXml() : Le chargement du conducteur 4 7 a echoue
Diagram::fromXml() : Le chargement du conducteur 2 18 a echoue
Diagram::fromXml() : Le chargement du conducteur 5 36 a echoue
Diagram::fromXml() : Le chargement du conducteur 2 19 a echoue
Diagram::fromXml() : Le chargement du conducteur 5 37 a echoue
Diagram::fromXml() : Le chargement du conducteur 4 6 a echoue
Diagram::fromXml() : Le chargement du conducteur 1 25 a echoue
Diagram::fromXml() : Le chargement du conducteur 4 10 a echoue
Diagram::fromXml() : Le chargement du conducteur 2 12 a echoue
Diagram::fromXml() : Le chargement du conducteur 5 38 a echoue
Diagram::fromXml() : Le chargement du conducteur 39 1 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 3 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 2 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 1 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 8 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 7 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 6 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 5 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 12 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 11 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 10 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 16 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 15 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 14 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 13 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 4 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 19 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 18 a echoue
Diagram::fromXml() : Le chargement du conducteur 0 20 a echoue
Re: Missing element
I love Linux,  for the fact that you can open a terminal. Yes, indeed, the missing components from the library. Below is a small part of all messages.
The element :  "/home/aleksandr/.qet/elements/anly503.elmt" haven't got an uuid, please edit and save this element with element editor to create an uuid
The element :  "/home/aleksandr/.qet/elements/centrifugal_contact.elmt" haven't got an uuid, please edit and save this element with element editor to create an uuid
element error.png, 44.9 kb, 471 x 336
Re: Missing element
Only question. How do uuid?
Re: Missing element
It's not very serious, the program will generate provisionally for each launch Qet.
For one or two elements just edit these elements and save.
If you have a lot of element for add this XML attribute, you need this bash script.
Get this bash script  in your Qet home element directory:
#!/bin/bash
# This script add attribut "uuid" in all .elmt files.
# need packages : sed, uuid-runtime, find
find . -type f -name "*.elmt" -exec sh -c 'UUID="$(uuidgen | awk '"'"'{print toupper($0)}'"'"')" ; sed -i '"'"'s#\(\).*\(<names>\)#\1'"'"'"<uuid uuid=\"{$UUID}\"/>"'"'"'\2#'"'"' "{}"' \;
# Go to Qet user element folder.
cd ~/.qet/elements/
# Download script.
wget https://download.qelectrotech.org/qet/scripts/elmt_gen_uuid.sh
# Make it executable.
chmod +x elmt_gen_uuid.sh
# Run script
./elmt_gen_uuid.sh
FYI, if element contain already an UUID, UUID is erased by new, yes this a minimal script that i make to add this XML attribute for official collection (2600 elements) when we add this feature.
BTW, you can improve it, and send me.
For MS Windows platform, you need Cygwin program or wait Win 10 + bash release in June. nomicons/getlost
http://www.theverge.com/2016/3/30/11331 … buntu-bash
Re: Missing element
Thank you. We will try to recover!
Re: Missing element
It's solved for embedded element collection.
Thank you for reporting this bug.
Revision: 4420
Author:   blacksun
Date:     2016-04-03 19:01:44 +0200 (Sun, 03 Apr 2016)
Log Message:
Fix regression with embedded element collection
